wacky speedometer, abs light on,overdrive flashing
we just bought a used 97 ford f350 7.3 powerstroke diesel. took it to have brake work done last week. seemed fine. then a few days ago, the speedometer would go all crazy back and forth when we go over rough spots in the roads and over bumps. but seemingly only when the rear tires would go over the bumps. this has been going on for a few days now. then today, the speedometer pegged to the max and stayed there. and the abs light came on and stayed on. also the overdrive was flashing. we got to where we were going and shut the truck off. after getting back in it and restarting the speedometer started working again but was all over the place like it has been for the last few days. we were almost back to town when it started running really rough. like no power. it sounded bad. after leaving it sit a few hours we went back to start it again. it started but sounds really horrible. anyone have any ideas?
The first part sounds like a vss issue but the vss while not cause the motor to run bad. With the OD flashing it should be shifting hard (its in limp mode) don't drive it much in limp mode it can cause major problems.
The vss is on top of the rearend. Check the plug and wiring to it and pull the vss out and clean the end of it and see if that helps
