Changing Frames
Old Apr 28, 2003 | 11:43 AM
captkane's Avatar
captkane
Changing Frames
I have a 76 ford f250 4wheel drive. I was wondering what problems i would run into if i wanted to swap frames with a 78 ford fram. I am able to get my hands on a 78 frame because i would like to get a bigger gas tank in the back plus redue the frame. My 76 body is in great conditions, so i just want to swap everthing over to the other frame.
How hard would this be or what problems would i run into.
Plus i would like to keep the same lift that is on my 76.
Any help would be great. Thanks
Old Apr 28, 2003 | 01:24 PM
fatdaddy's Avatar
fatdaddy
Changing Frames
you might want to check the Width of the spring perches on your axles vs the 78. Or measure the width of the frame rails as I think the 76 has a narrower frame. If true..the spring perchs will have to be moved out further out. also, the width of the spring leafs maybe wider for 78 than for 76. fd
