turn signals
Old Mar 21, 2012 | 01:22 AM
1980 Ford F-250's Avatar
1980 Ford F-250
turn signals
My 76 f150's turn signals are not working! I did some research and found that the light sockets being bad could cause this. I looked at all my sockets, and only one of them has corrosion on it. So i figured that was my problem.... Until I turned on the hazard lights. When the hazard lights are on, the lights flash on all 4 corners. So i am guessing that the sockets aren't the problem. What could it be? My dad said that is a 'flasher' but i did not see one.
Any help would be appreciated,
Justin
Old Mar 21, 2012 | 07:44 AM
J ballan's Avatar
J ballan
Thats exactly what my 79 did and it ended up being the flasher. A easy way to check is to switch the flasher from the hazards and if it starts working again you know you found your problem. Good luck.
Old Mar 21, 2012 | 07:47 AM
OldStyle's Avatar
OldStyle
Rusty Roller
There are two flasher units. They are located under the dash to the left of the steering wheel. Originally one was clipped onto the body above the e-brake.
irlfan360
17
Jun 3, 2015 01:18 PM
gt8684
Sep 18, 2009 03:04 AM
Ranger GT2
Electrical Systems/Wiring
Jun 3, 2006 04:22 PM
FMax
Jul 12, 2004 10:05 PM
Gobstopper
Mar 24, 2002 11:56 PM
