6.9 or 7.3 into a '72to'78 Ranchero
I'll be moving to Arizona later this year and am looking at picking up a 1972-1978 Ranchero. I'd like to replace the engine with a 6.9 or better still a 7.3 Power stroke. The 351M to 460's all had C-6's behind them so the frame mounts and crossmember are there for the 6.9's C-6. I'll box the frame from the front to the firewall and make new mounts for the 6.9. As for the C-6 I'll run a gear-vender O/D to get good mileage. I want to run it on homemade bio-diesel. I'd like to run the 7.3 Power Stroke(for max mileage) if the bellhousing pattern is the same as the 6.9,but I don't know if anyone makes a wiring kit to drop the power stoke into an older Pickup or if the factory wiring harness can be used(with mods).
This isn't my first engine swap and if the 6.9/7.3 is too wide for the Ranchero then I'll go to plan B which is a F-150 Short-bed. I already know that the 6.9 will fit using the F-250 frame mounts and the coil springs from the F-250 will fit the F-150. I was just looking at the Ranchero as it is already low and it looks so good(1972 model!). If I go the F-150 route I'll have to lower the truck to get it were I want it. More than likely that will mean Air bags .
The 72-78 Ranchero wont have shock towers. Those models are full frame, full size vehicles. The chassis is the same under the LTD, Torino, 77-79 Thunderbirds ect. It is a full box, full perimeter frame. I have a big block in a 79 Thunderbird, and there is plenty of room. Now a Powerstroke, that is still gonna take a lot more room.
Steve S.
To many to list
Steve S.
To many to list
Take a good look at Ford truck diesel radiators before going too far planning that swap into a Ranchero. I think you may do better with a smaller diesel like the Brazilian one from a cab-over, or an old Mercedes
On edit - just realized the date of the OP - bet he's moved on by now. Slow moving forum!
Good luck,
- Jeff
Good luck,
- Jeff
RFAgrasshopper
03-26-2012 10:24 PM
RFAgrasshopper
24
03-25-2012 04:36 AM
