My wife's truck got sluggish, then got better and had a error message stating "check throttle control sensor", but when I plugged in the scanner, I got a P061B, and read "Alternative Fuel Control Module RAM/ROM"
Doesn't make sense to me what one has to do with the other unless they're completely different things??
I can't find any info on the module with that code.
The Throttle Control Sensor seems easy enough to fix, but the other thing has me baffled.
P061B-Internal Control Module Torque Calculation Performance. P061B indicates a calculation error occurred in the powertrain control module. This code set in conjunction with P2106. See possible causes for DTC P2106.
