Parts Swap?
Old Apr 28, 2003 | 12:06 AM
f1drivr's Avatar
f1drivr
Parts Swap?
Will any of the parts interchange between a 239 & 292 Y-blocks? I'm wanting to use a newer 2 barrel intake from a 292 on a 239 block. THANKS
Old Apr 29, 2003 | 08:48 PM
286merc's Avatar
286merc
Parts Swap?
Intake will not fit 239 heads, however you can install later heads and intake together. Then you have to change the distributor, drive gear, oil pump and drive rod so you can use a modern carb.
A lot easier to find a 272-292 and drop it in and then just match dizzy with the carb/intake.
Old Apr 30, 2003 | 09:09 PM
f1drivr's Avatar
f1drivr
Parts Swap?
Thanks for your reply. I guess for know, I'll rebuild the old carb on the 239 & stick with it until I rebuild the 292. Thanks for the info.
