1978 - 1996 Big Bronco
Pinion Angle
Old Mar 18, 2012 | 09:10 PM
Captbs32's Avatar
Captbs32
Pinion Angle
I am trying to find our what shims I should I get or will the stock shims be sufficient?
Old Mar 18, 2012 | 09:14 PM
Raleigh1's Avatar
Raleigh1
What are the details? Lift? Shackle flip? Why are you replacing the shims?
Old Mar 18, 2012 | 09:43 PM
Captbs32's Avatar
Captbs32
I have a six" lift with the stock shims.
The reason I am thinking about replacing the shims is to correct the angle of the driveshaft and not have so much angle on the U-Joints.
Old Mar 18, 2012 | 10:42 PM
Raleigh1's Avatar
Raleigh1
Okay so do you have blocks or springs? Either way they have the proper correction built it.
Are you having excess vibration?
Old Mar 18, 2012 | 10:50 PM
Captbs32's Avatar
Captbs32
Blocks... Regardless
no all good there. Rides as good as a Bronco would.
My pinion seal started leaking close to the time I put the lift on. Maybe it was just its time to go. The angle looks sharp to me but that may just be me.
Old Mar 18, 2012 | 11:04 PM
Raleigh1's Avatar
Raleigh1
Can you snap a pic of it?
Here is a pic of mine with 6" lift by means of a shackle flip and add a leaf.
This is with NO shim at all.
Old Mar 18, 2012 | 11:20 PM
Captbs32's Avatar
Captbs32
No, I am in Taiwan til the end of the month. When I get back I can.
But my angle of the third member and the yoke is a lot more then yours.
How much was that driveshaft? I am still running the stock.
Mine only show like 2 (2 1/2)" of spline but I am worried about flexing out and one it coming out and dirt and that stuff getting in the diff.
justcruzin125
Aug 19, 2016 05:05 PM
f150light
13
Aug 31, 2012 11:33 PM
emmagator
Apr 4, 2011 05:37 PM
masterc16
29
Jun 2, 2007 10:59 AM
oneofakind97
Offroad & 4x4
Feb 27, 2007 06:32 PM
