Steering Box Adjustment
Old Mar 17, 2012 | 02:33 PM
midsouth's Avatar
midsouth
Ok, I got the screw to move. Like an idiot, I unscrewed it all the way which made the steering tight. Should I screw it in all the way and then back out 1/4 turn? Once a turn is completed, the steering has to be assisted back to straight. Plus, when moving down the road, it floats left and right. I understand that there's going to be some play. It's an 83 f150 4x4 5.8L. Any advice would be appreciated.
Old Mar 18, 2012 | 08:21 AM
Gary Lewis's Avatar
Gary Lewis
You may be in trouble. Serious trouble. There may be a way to figure out where it should be set, but they really should not be messed with. You can keep adjusting it by an 1/8 turn at a time until you get it acceptable, but I doubt it. I think you will have to replace the box, and they cost $150 rebuilt.
Old Mar 18, 2012 | 08:30 AM
82f100460's Avatar
82f100460
Darn...was hoping you were going to say it was easy...mine has some slop in it too and was hoping to adjust it out. But it has a leak too so probably just best to replace. Besides getting the pitman arm off, looks to be a fairly straight forward job?
Old Mar 18, 2012 | 08:44 AM
Gary Lewis's Avatar
Gary Lewis
You can adjust it, and maybe get some of the slop out. But, only some and you will also start losing "feel". In my experience you lose the feel long before the slop, and driving gets tedious as it won't stay where you put it on the road.
Yes, getting the arm off is the hard part. The slip-joint can be a pain to get loose. And, by the way, make sure the slop is in the box and not the rag joint or tie-rod ends.
Old Mar 18, 2012 | 09:19 AM
82f100460's Avatar
82f100460
Right...already replaced all that. box is the only thing in the steering that is not new. Tie Rod ends where a complete wreck. Runs straight and very smooth now...just a little slop and a little leak. Neither on the top of the list yet...neither are too bad. Actually think the leak is from the HP hose and is just dripping down on the box. But we're talking about a couple drops here and there. Not enough to leave a puddle anywhere.
Old Mar 18, 2012 | 04:28 PM
midsouth's Avatar
midsouth
I'll check the tie rods before I attempt the box. It's strange that this just happened, but more strange that it drives as if the manuel locking hubs were set on lock instead of free which is where they have been. Any suggestions on where to search for a rebuilt box if everything else checks out?
Old Mar 18, 2012 | 04:38 PM
82f100460's Avatar
82f100460
most any of the major part store will have a rebuilt box. In the range of $150
If you end up doing that pay some particular attention to how it is all set know. pull in nice and straight with your wheels staight. Mark where you pitman arm is on the shaft now...you will want to get it back on the new gear in the right spot.
Old Mar 18, 2012 | 09:58 PM
critterf1's Avatar
critterf1
They should have a "master" spline. IIRC.
fuzzy1626
Jun 21, 2007 02:58 PM
77f2504by4
Dec 11, 2006 05:50 PM
agryphon
1983 - 2012 Ranger & B-Series
Sep 28, 2006 10:11 PM
WildBill Racing
Apr 28, 2006 06:47 PM
weatherguard
Jul 15, 2004 05:35 AM
