Old Mar 16, 2012 | 10:54 PM
dustin schafer's Avatar
dustin schafer
I have a 2002 ford 7.3 diesel and i done a couple of things to it like a straight pipe and taken the insalation off of the pipe coming off the intake. I was wondering if there is any other things that i can do to it that will boost the power a little without buying anything for it right now. THANKS
Old Mar 17, 2012 | 04:38 PM
Kajtek1's Avatar
Kajtek1
Taking insulation off will lower the power. Not in the amount that you might notice, but Ford put this insulation for a reason.
Welcome to the forum and visit the engine section for more details.
Old Mar 17, 2012 | 05:41 PM
BobbyDiesel71's Avatar
BobbyDiesel71
welcome to FTE!
post your qestions in the 7.3 diesel truck engine section
Old Mar 18, 2012 | 01:31 AM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Mar 18, 2012 | 09:32 AM
Bad Notch's Avatar
Bad Notch
Cut the muffler out of the stock exhaust and put a drop in K&N Filter
Old Mar 18, 2012 | 11:57 AM
TNT in Round Rock's Avatar
TNT in Round Rock
how exactly does removing that insulation cause a loss of power ????
Old Mar 18, 2012 | 12:03 PM
DND58's Avatar
DND58
Pretty sure the insulation is there to tone down turbo whistle.
Old Mar 18, 2012 | 02:23 PM
F250_'s Avatar
F250_
"Power loss" is based upon physics, and the amount of loss or gain may not be felt, even though it is there all the same.
The insulation on the intercooler inlet tube is there to minimize the absorption of heat from the engine bay, and it also has a side benefit of reducing turbo whistle as well. If the air coming through that tube heats up from the surrounding engine bay heat, then it will expand in volume and therefore begin to impose a limit on the air flow through your system.
The reverse situation is to use a water/meth injection system which actually cools down the gases flowing from the turbo into the intercooler, and this reduces the amount of back pressure which the turbo is having to work against to shove air into your intake plenums.
All this works because colder air takes up less volume (is more dense), and therefore allows your turbo to push more lbs of air (oxygen) into your engine. Anything which allows your incoming air to heat up will result in some amount of power loss, even if you cannot feel it in the seat of your pants. Conversely, anything you do to cool down your air intake will result in increased power, again, even if you cannot feel it in the seat of your pants.
Old Mar 18, 2012 | 09:23 PM
dustin schafer
I took the insulation off for more turbo noise which helped but i dont think it was worth the work. This is my first diesel so i dont know much of what to do to them for more power. I am going to get a cold air intake and a aftermarket turbo later but for now i was just wondering if i could do little things to it to give it a little.
Old Mar 18, 2012 | 10:02 PM
emery72's Avatar
emery72
The 6637 intake is a very inexpensive mod that is very popular. It isn't free, but you can build it yourself pretty cheaply.
Old Mar 19, 2012 | 12:35 AM
Bonanza35's Avatar
Bonanza35
Don't use the K&N airfilter. More then one person found out the hard way. Also when it get wet it will block air to the engine. I had a freind have that problem when towing and finally got rid of it.
Chet
Old Mar 19, 2012 | 01:40 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Foil delete is quick and easy with a wire wheel on a dye grinder or electric drill...My turbo whistles at me quite a lot now. My wife even likes it!
Old Mar 19, 2012 | 08:42 PM
dustin schafer
what is the foil delete
Old Mar 19, 2012 | 08:45 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Removing the silver insulation from the pipe going from the turbo to the intercooler
Old Mar 19, 2012 | 10:57 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Do not do this.. Just dont. You will thank me later.
