Modular V10 (6.8l)
engine knocking
Old Mar 15, 2012 | 03:24 AM
usmcdragon's Avatar
usmcdragon
engine knocking
i need help with this please. I was driving my X on the freeway, took my exit i needed and my engine starts to knock really loud. Then my engine stalled. I was able to get it in a parking lot luckily. I tried to start it and it took it awhile to start. I was able to drive it to a buddy's house but i noticed a loss in power. It didn't have the same get up it had before this happened. Please help it is my only truck for my family. Also i have looked into Google about this, a few things and want to confirm it before i start taking this apart. And hopefully its an easy problem but i doubt it.
Old Mar 15, 2012 | 04:23 AM
Ironhand03's Avatar
Ironhand03
Which engine? Need some more details.
Old Mar 15, 2012 | 09:58 AM
usmcdragon's Avatar
usmcdragon
Its the 2000 v10 6.8lt 4X2
Old Mar 15, 2012 | 10:33 AM
Ironhand03's Avatar
Ironhand03
Loss of power going down the road plus hard starting.
I would look at the alternator. It may be weak or failing and slowly starting to take the battery with it. Have both tested.
Old Mar 15, 2012 | 01:55 PM
Stewart_H's Avatar
Stewart_H
Moved to the Modular V10 6.8L forum.
Stewart
Old Mar 15, 2012 | 03:03 PM
jh818's Avatar
jh818
I wonder if what you're experiencing is a misfire?
Old Mar 16, 2012 | 02:12 PM
usmcdragon's Avatar
usmcdragon
Got the alt off and checked came up bad. So now i am going change the alt and spark plugs and see if that works.
Old Mar 16, 2012 | 09:03 PM
usmcdragon's Avatar
usmcdragon
changed the alt and plugs no joy. still is knocking. at least it doesnt stall at idle now. can someone please tell me what else it could be. already opened the valve cover and everything looked good. can the type of oil i use cause this just wondering.
Old Mar 16, 2012 | 09:16 PM
Ironhand03's Avatar
Ironhand03
Have you checked the oil level? What oil do you use? Did you have the battery tested as well?
Old Mar 16, 2012 | 09:57 PM
usmcdragon's Avatar
usmcdragon
Did an oil change to see if there was anything in the oil and i used 10w40. And the battery is good.
Old Mar 16, 2012 | 10:46 PM
Ironhand03's Avatar
Ironhand03
Try to isolate the location of the knock. See if its in the top end or bottom end of the motor and if you can get close to were its coming from.
Then go from there. It will help determine root causes.
Old Mar 16, 2012 | 10:57 PM
usmcdragon's Avatar
usmcdragon
I press on the gas and the engine goes down to like 500 rpm and almost stalls. Is there a way to check the oil pump?
Old Mar 16, 2012 | 10:58 PM
Ironhand03's Avatar
Ironhand03
Sounds like its going lean. I would check for any fuel or spark issues.
Old Mar 16, 2012 | 11:00 PM
jh818's Avatar
jh818
I believe your engine takes 5W-30. My '02 takes 5W-20.
Old Mar 16, 2012 | 11:02 PM
Ironhand03's Avatar
Ironhand03
That wont change anything. Most 40s will shear to a high 20 or mid 30 grade anyways.
