Brief smoke on cold start
The exhaust components have remained the same.
Any ideas?
Oil can leak past the valve guides when sitting for a few or more hours. Either worn guides or the valve stem seals can cause this.
The best fix is to use PC seals.
The easiest way to check it is to hook up an air compressor with an adapter that screws into a spark plug hole, after reading the plugs to find the offending cylinder(s).
Fill the chamber with air and listen for hissing to pinpoint where the leak is. If it sounds like it's coming from the top, it's the guides or seals. If you hear it at the oil pan it's rings but I doubt that if it doesn't smoke after warm up. (A ring could be damaged during installation or break in)
Hope this helps!
