Intake Leak
Old Mar 14, 2012 | 10:00 AM
endobear's Avatar
endobear
Intake Leak
Long story short. I hit a 20 rifle gun safe in the middle of the highway 900 miles from home, 2 miles from purchasing a new to me 34' trailer. Had to take the truck to the stealership to get the allignment fixed and check to see if I was safe for the drive home. They got my allignment all squared away and sent me on my way. When I got home I looked through the paper work and saw that they had found a few issues with my truck one of them being an intake leak.
I looked around and couldnt find what they could have been talking about. Its still got the stock filter setup. For now. This may be my excuse to upgrade.
Is there a typical place that the intake leaks?
I called the stealership and they couldnt tell me squat.
Old Mar 14, 2012 | 10:44 AM
woodnthings's Avatar
woodnthings
What are you driving? Hopefully a 99-03 Superduty with a 7.3L as that is the forum you are in.
The intake filters (K&N) are known to not seal real well. That causes dusting and leads to big problems.
Old Mar 14, 2012 | 11:04 AM
endobear's Avatar
endobear
Sorry, Its an 02 f350 7.3 with the stock air box and filter.
Old Mar 14, 2012 | 12:01 PM
woodnthings
It is hard to say what they determined as an intake leak. The intercooler boots, could be written that way also. If they did, I would assume they saw oil residue on the boots.
Old Mar 14, 2012 | 01:54 PM
JT250's Avatar
JT250
if there is a leak between the filter and the turbo the inside of the intake will be dusty because it will allow it to suck in dirt. if it is after the turbo you can make a boost leak detector to find it.
Old Mar 14, 2012 | 02:25 PM
endobear's Avatar
endobear
Looks like the intercooler boots are leaking for sure.
Thanks for the input. Im going to assume that thats what they were talking about because I cant see any were else that could be leaking.
Perfect time to do the 6.0 intercooler swap Ive been dying to do.
Old Mar 14, 2012 | 02:30 PM
PaysonPSD's Avatar
PaysonPSD
Check for dust inside the air box and the tube going to the turbo intake.
They might have seen dust there and that would indicate an intake leak.
Old Mar 15, 2012 | 04:36 PM
endobear's Avatar
endobear
Very little dust in the intake tube. Looks pretty normal in there for never being touched in 10 years.
Old Mar 15, 2012 | 04:37 PM
endobear's Avatar
endobear
Im pretty sure they didnt do a boost leak test.
hivoltj
Sep 27, 2017 12:48 PM
mcguyverii
Nov 2, 2013 12:01 AM
65F100390
Nov 3, 2010 06:28 PM
workingdog
24
Jan 19, 2007 05:25 PM
toque
May 19, 2005 09:43 AM
