Ac
Old Mar 14, 2012 | 07:50 AM
Kaizer88's Avatar
Kaizer88
Ac
Got a 89 f150 and my ac switches from blowin in my face to defrost at 65 mph. It stil blows ice cold out the defrost vent. What could it be.
Old Mar 14, 2012 | 08:25 AM
rla2005's Avatar
rla2005
More than likely you have the infamous white vacuum supply line for the HVAC system that has aged and cracked. Here is a thread about the subject and resolution from another forum: A/C and/or heater stuck on defrost - FSB Forums
Old Mar 14, 2012 | 08:30 AM
subford's Avatar
subford
This is the white vacuum line he is referring too.
Old Mar 14, 2012 | 09:40 AM
rla2005's Avatar
rla2005
Thanks, Bill!
Old Mar 14, 2012 | 02:37 PM
Kaizer88's Avatar
Kaizer88
ok i put a new rubber line over that white cracked line it blows nice and hard up to 65 and once i hit 70 75 if i let off the accelrater a lil bit and starts blowing in my face. could i not be getting a good enough vaccumn?
Old Mar 14, 2012 | 07:28 PM
yardbird's Avatar
yardbird
Look at the check valve coming from the engine vacuum. It should be a big line coming in, then the check valve is a T. These will go bad, causing vaccum to leak back into the engine during acceleration. You should be able to suck through the engine side connector, but not blow through it.
Old Mar 14, 2012 | 09:27 PM
rla2005's Avatar
rla2005
Don't forget the little plastic vacuum reservoir mounted to the side of the blower motor case. Mine was cracked. These trucks are way under powered, low to almost no vacuum at higher speeds is not unusual. A tired engine or poor state of tune brings these vacuum operated systems to their knees. You need to check the HVAC circuits with a vacuum pump/gauge. The thread URL I posted has some good info of where those vacuum lines go.
marsh2424
Feb 9, 2019 11:01 AM
CraigK
24
Aug 8, 2010 07:43 PM
robr0924
Nov 16, 2007 07:46 AM
crazie0025
Oct 19, 2006 11:12 PM
Jack01
Aug 30, 2005 09:02 PM
