Towing with Tuner
Old Mar 13, 2012 | 07:09 AM
machine62's Avatar
machine62
Towing with Tuner
I know there aren't too many of us out there yet that have took the plunge and tuned our 6.7's but I am looking for a little advise either with the 6.7 or past experience with a 6.4. Tomorrow I am picking up my first fifth wheel which is a 2012 Landmark San Antonio and the dry weight on it is 13,500. Just looking for any suggestions on the tuner settings as far as power goes (mild, wild, or hot). I know the truck has plenty of power stock but would like to know what setting would be best for fuel mileage, engine longevity, and performance.
Thanks in advance.
P.S. Pictures will follow tomorrow
Old Mar 13, 2012 | 07:49 AM
senix's Avatar
senix
heavier you tow...closer to stock power you should be.
My rule cuts off at the 10K mark. Anything over 10K I am at stock power levels. Course mine is a 6.4.
Wait for the 6.7's to chime in.
Old Mar 13, 2012 | 08:00 AM
darren32's Avatar
darren32
We towed our 5th wheel quite a bit this summer. It's 35' and about 11 - 12,000 lb. My opinion is.....
IT'S GREAT!!!
But I think you have to be careful, I almost ONLY tow on mild.
I set the defuel to EGT = 1,450 F, Coolant = 220F. It will defuel on wild on EGT but never get there on mild. It has defueled on mild on the coolant temp on long uphills though. I also ended setting a defuel for boost at 35 PSI (which I remove when not towing). I found that even on mild, towing, it would pull some really high pressures for an extended period of time. But I am also on a really old TV. For example, it held 38 PSI up a 9% grade for a FEW MILES. The power was great but the turbo SOUNDED like it was being pushed past where it should be (at least to me). Being able to set the defuel levels to your comfort level is great.
What trans tune are you running? I towed with H&S trans tune and I hated it (obviously it is not designed for towing). It lock the TC WAY to early which can be almost dangerous if you need to get off the line quick. I tow with Ford trans tune now.
Thanks and have a good trip!
Old Mar 13, 2012 | 09:29 AM
machine62's Avatar
machine62
Thanks guys for the information. That is very helpful. Right now I am running the stock trans programming. I tried the H&S trans tuning and hated it so I returned back to stock. I thought they were going to be making some changes, to the T/C locking especially as you have mentioned, but I havent seen any updates yet.
Old Mar 13, 2012 | 12:44 PM
jdadamsjr's Avatar
jdadamsjr
tell me more about the tuners you have - am interested - like the stock power, but you always want....
More
Old Mar 13, 2012 | 01:15 PM
PrinceValium's Avatar
PrinceValium
Wow I just watched the picture show of that trailer and it is quite impressive!! It reminds me a lot of the Grand Junction my wife and I looked at last year. They are basically like towing a house! Congrats!
Old Mar 13, 2012 | 01:20 PM
darren32's Avatar
darren32
More
Mine is H&S Black Maxx (and I believe machine62 is the same??)
You can find lots of information here:
’11-’12 6.7L Powerstroke - H&S Performance
The power is great, goes from about 333hp/677tq stock to 497hp/1044tq on hot at the rear wheels.
I deleted my complete EGR but now they have a kit where you only take out the tubes (I think). It's easier as you don't have to drain the coolant and cap the lines etc. You can check it out here:
http://www.hsperformance.com/images/fordegt.pdf
Or the full EGR delete here:
http://www.hsperformance.com/images/fordegr.pdf
And tuner install information here:
http://www.hsperformance.com/images/blackmaxx.pdf
The other option (that I know of) is Spartan but I don't know too many people with their tuners. Had I known most people were going to go H&S I prob would have went with Spartan just te be different. Not that I have had any issues with H&S other than this one:
https://www.ford-trucks.com/forums/1...-heads-up.html
Thanks
Old Mar 13, 2012 | 01:48 PM
machine62's Avatar
machine62
I have the black maxx as well.
The trailer is very nice. I am looking forward to staying in it. I will post pictures tomorrow when I pick it up.
Old Mar 13, 2012 | 02:05 PM
Shepardsonp's Avatar
Shepardsonp
Thanks in advance.
I pull a 16,000 lb fiver in the mountains of Colorado - no trouble with a stock 6.7L. Why do you think you need a tuner?? BTDT and not going there again.
Towing+Tuner = Trouble.
It's just a matter of time.
That's my opinion and we all know that opinions are like (inser here), everyone has one.
Old Mar 13, 2012 | 02:07 PM
Shepardsonp
Thanks in advance.
That's my opinion and we all know that opinions are like (insert here), everyone has one.
Old Mar 13, 2012 | 02:09 PM
darren32's Avatar
darren32
It's OK to have an opinion but you can only have it once.
Postin it twice doesn't help
Old Mar 13, 2012 | 02:13 PM
Shepardsonp
Good one!!
Old Mar 13, 2012 | 10:47 PM
jdadamsjr's Avatar
jdadamsjr
Darn Darren, you can't help me anymore as I can't give you reps cuz I gave u too many already !!!
What's the purpose of Reps if you can't give them to the person that helps ?!?!?
Sounds like a gooberment program where we have to spread it around
but thanks guy !!!
Old Mar 14, 2012 | 01:06 AM
brandon4's Avatar
brandon4
I pull 20k lbs on mild and it does very well. Nary a problem.
Old Mar 15, 2012 | 06:48 AM
machine62's Avatar
machine62
Well I picked her up yesterday and uploaded a couple of crappy pics to my gallery. All I can do for now. The truck pulled it flawlessly with the tuner set on mild and I managed to get 11.5 mpg for the short distance I went. Life is good
