instrument cluster
Old Apr 27, 2003 | 09:55 AM
Ford_a_holic's Avatar
Ford_a_holic
instrument cluster
If i swap in a new instrument cluster can i change the odometer to my milage or will i have to start all over again
Old Apr 27, 2003 | 12:06 PM
MustangGT221's Avatar
MustangGT221
instrument cluster
What year/type vehicle are you talking about?
Old Apr 27, 2003 | 01:42 PM
steve83's Avatar
steve83
instrument cluster
If it's a '92-96 truck/Bronco, it has a PSOM, and if you buy new, the dealer will probably insist on setting it to your current mileage. If not, you can hook it up to your stereo and use a tone generator (like GoldWave) to roll the miles up, but it takes a while.
If it's a mechanical odometer, you can pull the cross-shaft and roll the dials to wherever you want, but it's a pain to get it back together right, and sometimes the numbers will rub off if you touch the wheels too much.
Old Apr 27, 2003 | 02:28 PM
StrangeRanger's Avatar
StrangeRanger
instrument cluster
If it's amechanical odo, just chuck the tranny end of the cable in a drill motor and run it to wherever you want it..
Old Apr 27, 2003 | 04:16 PM
Ford_a_holic
instrument cluster
its a 92 and thanks for all the info what i want to do is put in a lightning instrument cluster cause i have a standard tranny and my dosnt come with a tach plus the spedo goes to 120
Old Apr 28, 2003 | 01:12 AM
charlez's Avatar
charlez
instrument cluster
This link should help you out.....
Gauge Change...
Old May 11, 2003 | 11:16 AM
steve83's Avatar
steve83
instrument cluster
I use my stereo to set mileage on PSOMs. Setting the conversion constant is easy, too.
