fuel problem
Old Mar 12, 2012 | 03:31 PM
jason kitch's Avatar
jason kitch
fuel problem
i have a 1995 f150 4.9. The front fuel tank has not run for awhile. when it is on the rear tank it runs fine, when i switch it to the front tank the engine dies. i have checked the ground on the radiator support and its fine, replaced the relay, checked the fuel shutoff switch and it is work ing. I recently have replaced both fuel pumps, sending units, and tank selector switch. front tank still will not work.
If i run a jumper wire on the back of the switch the front tank will turn on and the truck will run. I cant rememeber the colors but it was a main power wire to the pump power wire I also think it was the bottom two wires on the switch.
any ideas what going on.
thanks jason
Old Mar 12, 2012 | 03:56 PM
subford's Avatar
subford
Would be a bad plug or switch.
Old Mar 12, 2012 | 04:07 PM
jason kitch
which plug might it be and I thought i would try buying another switch, on the chance that one i just got was bad.
thank you
Old Mar 12, 2012 | 04:35 PM
subford's Avatar
subford
The plug that plugs on to the selector switch.
Old Mar 12, 2012 | 05:23 PM
jason kitch
thanks for all the help.. any ideas where i could order a new plug
jason
Old Apr 13, 2012 | 02:10 PM
jason kitch
I tried a new switch and still nothing. Was wandering what in the plug would be bad and where would I gets a new plug to fix the
Problem
Old Apr 13, 2012 | 02:23 PM
subford's Avatar
subford
I do not know what to say. You say you put power on the wire at the selector switch and the pump runs. You say the other pump runs when selected by the selector switch.
So the problem has to be right at the selector switch or its plug.
Now you say you have replaced the selector switch and it still does not run.
It sounds like you are pulling my leg on this one so by by.
Old Apr 13, 2012 | 03:04 PM
jason kitch
Well tanks for the help anyways. If I ever figure out the problem I will post a reply
sward0318
Dec 19, 2018 09:57 PM
retsyr
20
Jan 22, 2017 07:22 PM
Serg
Feb 20, 2014 09:17 PM
fordforlife4x4
Jun 27, 2013 06:49 PM
JHAM
Jan 27, 2011 10:05 PM
