Intermittent wiper control
Old Mar 11, 2012 | 10:07 AM
MS82F150XLT's Avatar
MS82F150XLT
Ok so yesterday I went to my JY to hunt an intermittent wiper control. I found one on an 81 Ranger, she was very cooperative.
I pulled mine out 82f150xlt. Swapped it in and it works except for the timer. If you turn counterclockwise from of the wipers cycle once and no more.
Does anyone know how to test or fix it? All other functions work fine. Thanks!!!
Old Mar 11, 2012 | 10:51 AM
ctubutis's Avatar
ctubutis
I am assuming you also have the governor (black box) correct?
Old Mar 11, 2012 | 11:12 AM
MS82F150XLT
Yes, the black box got hooked up also.
ctubutis's Avatar
ctubutis
Intermittent wiper control testing
Here is what the 1981 EVTM says to do to test things:
Old Mar 11, 2012 | 01:40 PM
JimsRebel's Avatar
JimsRebel
did you hookup the loose ground wire?
Old Mar 11, 2012 | 03:45 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Can you hear the box clicking after the first pass of the wipers? No clicking would indicate a problem in the timer function, while clicking without the wipers moving would indicate bad contacts (corroded, most likely) inside the box.
If it does make the clicking noise, let it run for a bit at the fastest setting. Repeatedly attempting to make contact can clear away the corrosion in many cases.
Old Mar 11, 2012 | 03:50 PM
MS82F150XLT
Yes, hooked it up to a newly sanded spot on the bottom of the dash rail.
I haven't had a chance to pull it and test but I turned on the intermittent and and it will cycle, a long time between, and seemingly no adjustment of cycle speed.
ibuzzard
Oct 22, 2019 07:54 AM
turnrjr
Ford Truck Parts for Sale
Dec 26, 2017 07:33 AM
PapaBearYuma
17
Jan 15, 2017 07:31 PM
southtexasidi
17
Dec 16, 2014 09:28 AM
