Sheet metal availability
Old Mar 12, 2012 | 08:11 AM
elgemcdlf's Avatar
elgemcdlf
Originally Posted by 62FE4x4
That definitely helps. Now we know the 78 bed will bolt into the 62 frame without any mounting issues. What about the 78 fuel tank behind secured to the 62 frame?? I believe the 62 frame is narrower than the 78? Will the fuel tank (behind rear axle) still work?
I am not sure how you got there. The '78 truck is 4" longer in wheelbase than your truck & 2" of it is behind the cab for sure. I said I am not certain where the other 2" is. The fuel tank will not fit. The bump people use a Mustang tank. I believe it is a '70.
Old Mar 12, 2012 | 09:45 AM
62FE4x4's Avatar
62FE4x4
I got to that conclusion because we had been on the road 23 hours straight. Haha Thanks for correcting my thoughts. I didn't think the setup would work. Luckily I have a 59 bed I can use instead.
Old Mar 12, 2012 | 10:22 AM
elgemcdlf's Avatar
elgemcdlf
I believe your frame is the same width as a bump frame so the Mustang tank conversion should work.
winginit
Jul 12, 2015 05:42 PM
jimcar-9
Aug 13, 2013 09:54 PM
JoeKramer
Aug 4, 2008 08:45 PM
DKA-78
Nov 22, 2007 09:27 PM
lref250ld
Aug 26, 2007 07:55 AM
