I installed these funky little adapters at lunch, I will be zipping the excess bolt off the top.
Painted the rear shocks, I didn't care for the white since the accent will be silver I went with that.
I think the steering and radius arms will get the same color.
And I still need to get some better hardware, I will be going to get some bolts for the radius arms so I will probably get it all then.
Looks very good. I don't know so much about the shock color though, it looks too... "stock" IMHO but it still looks great nonetheless. What brand were thy again?
That would be pretty cool. Then you could do some ghost paint on it even from the Alsa Corp link i put in the sticky here. They have some awesome paints that you can put on chrome and it kind of ghosts it.
Well I was back at it today.
I think I got a lot done, but it doesn't look like much!
I got my radius arm brackets built. Drilling the 3/4" holes took forever!
By putting the brackets here i was able to use existing frame holes, I just had to open one up a bit.
The radius arms will end up being just over 50"!
I welded the 3/4" nuts to the ends of this 1.25" .25 wall tube, works AWESOME!
I measured the transfer case output, I should have about 3" clearance between it and the cross bar.
That looks great. I was about to ask why there was 2 bars connected to the radius arm bracket. The first picture makes it look like the bar on the floor is a second one.
