Bad Injector??
Old Mar 9, 2012 | 08:09 PM
freedawg_101's Avatar
freedawg_101
Bad Injector??
So my truck smokes like a frieght train when I start it and its not at operating temp. The smoke smells like raw diesel and visually goes away when the engine gets up to temperature, but still smells a little like raw fuel. So reading on the forums, I have started trubleshooting this problem. I have a new GPR, all new Glow Plugs, and good fuel pressure.
I traced the suspect injector by unpluging the VCH's one by one until the smoke stopped. After that I pulled the VC and unplugged the two injectors on that harness and found that one didnt make any change in the sound of the engine but did stop the smoke issue.
Since I can assume this is the injector haveing issues by the fact that I can unplug it and remedy the problem, the wire harness should be good I would think.... Or am I missing something?
Time for stage ones?
Old Mar 9, 2012 | 08:58 PM
fordpride's Avatar
fordpride
Swap the pass. and driver side UVCH and see if the problem follows the wiring if not the swap the injector you think is giving you problems with the one next to it to see if the problem follows the injector
Old Mar 9, 2012 | 09:07 PM
freedawg_101
The problem does follow the injector. I havent tried changing the harness from side to side yet, do you think I should even if it Follows the Injector?
Thanks for the reply.
Old Mar 9, 2012 | 09:25 PM
fordpride's Avatar
fordpride
If you moved the injector from it's original hole to another one and the problem followed it then you have a bad injector
Old Mar 9, 2012 | 09:35 PM
freedawg_101
Thats kinda what I figured just wanted to make sure before i went to napa and let the hose me for $359.
What if any mods are recommended if I go to stage 1's? Pillar gauges are soon to come.
Old Mar 9, 2012 | 09:42 PM
fordpride's Avatar
fordpride
I'd send the injectors to jim his budget build start at 500.
at least a pyro gauge with stage ones
Old Mar 9, 2012 | 09:48 PM
freedawg_101
So I could do the budget stage 1's with Jim? Is it recomended to change cups while doing the injectors or just o-rings?
Old Mar 9, 2012 | 10:05 PM
fordpride's Avatar
fordpride
Yep they'll just run like stock stick till you get a chip.
I wouldn't touch the cups unless you see a crack in one after you get the injectors out
KRDiesel
May 17, 2012 08:09 PM
tobacco farmer
Apr 21, 2010 04:34 PM
Rick2001
Feb 7, 2007 03:21 PM
fordf350crazy
Jul 27, 2005 05:37 PM
sean23johnson
Jun 15, 2005 11:03 PM
