7.3 hissing
Old Mar 8, 2012 | 08:31 PM
hopczar's Avatar
hopczar
7.3 hissing
Thank you for your help i. My 2001 f350 has 90,000 and makes a hissing noise when at part throttle and goes away at full throttle. My ebpv is disconnected and I just installed bellowed up pipes . My waste gate ARM is welded. I'm wondering if it could be the problem? I've checked my boots and cleaned them . Any help would be great.
Old Mar 24, 2012 | 09:19 PM
hopczar's Avatar
hopczar
The only time my wastegate makes the blow off noise is when I let off the go pedal and it continues till i full throttle it . Please help
Old Mar 24, 2012 | 10:03 PM
timmyboy76's Avatar
timmyboy76
Hey bro, was the arm welded prior to installing the uppies or at same time?
Old Mar 25, 2012 | 01:21 AM
woodnthings's Avatar
woodnthings
I am a little confused. Your EBPV rod is disconnected? Has the EBPV been gutted or do you have a non- EBPV housing?
You say your waste gate is welded, then you say it makes a blowoff noise?
Seems odd the way you describe it, sounds like the waste gate is still working, somewhat.
Old Mar 25, 2012 | 12:50 PM
hopczar's Avatar
hopczar
When I bought my truck the rod was welded . The power for the ebpv is is not hooked up . The rod is still hooked up . How do you load images I have one of the welded ARM ? Thank you
I have the picture in my albums
Old Mar 25, 2012 | 01:58 PM
woodnthings
You are better off loading the image to a host site like Photobucket.com, then pasting the IMG link here. I am not sure if you have enough posts (25) to attach pictures.
4mil
Feb 13, 2007 11:45 PM
ski52
Dec 2, 2006 03:31 PM
ozonejunkie
Apr 6, 2004 06:52 AM
