Thanks. I found this but it doesn't look like a 96 headlight. I saw on a 2000 model there is a clip but I can't find what releases the headlight assembly.
Look it up here instead. It's probably in the Body section, but maybe Electrical. There are 2 nuts down low, and many people recommend removing the battery & overflow/washer tank for easier access. There's a recent thread in one of the forums with pics.
hey steve!
FYI it's the same manual. Auto zone just placed the same chilton manual on their site. I like it because when i find the part or problem i am already on a site that i can look for it on.
the trim is onepiece with the cornering lite there is 2 screwz on the top rad support and the other are under the trim above the filler it is tite but they are there
after the trim is off you gotta pull thoise horsshoe clis they are a pain in the *** biggtyme and pull it just like it shows in the pictur you probly will distort the ****t outta the clips so get new ones as a body man my tool box stks those clips
