Fog light question
Old Mar 7, 2012 | 01:06 PM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Fog light question
Okay this is in regards to the plug. So if I took aftermarket lights (see below) and wiring harness (also pictured below). Could I cut the harness and wire the lights to the female side of the plug and then use that to plug into the factory fog light plugs? It sounds like it would work in my head but that doesn't mean a thing. So I need some input from you guys.
Old Mar 7, 2012 | 02:25 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Depends on the draw, stock fogs are about 45-55 watts, how much do those pull?
Old Mar 7, 2012 | 02:28 PM
TXtinct's Avatar
TXtinct
Specifications:
Flood Light Pattern
LED Power: 24W - 1440 Lumens
Operating Voltage: 10-30V DC
Waterproof rate: IP 67
8pcs high power*3W high intensity LEDs
Current draw 1.8A @ 12V,0.9A@24V
Color Temperature: 6000K
Waterproof and anti-corrosion: it can in the rain or harsh environments
Aluminum casing, shock-proof waterproof better
Wide operating voltage range: it can apply to different types of vehicles
Material: Diecast aluminum housing
Lens material: PMMA
Mounting Bracket: Stainless Steel
Long life: more than ordinary advanced LED light bulbs, more than 30000 hours life
Old Mar 7, 2012 | 02:33 PM
Toreador_Diesel
Hmmm.....
Where you gonna mount those things?
Old Mar 7, 2012 | 02:41 PM
TXtinct's Avatar
TXtinct
Originally Posted by Toreador_Diesel
Dude, plug your new fogs in and blind the world in front of you
Btw, where you gonna mount those things?
I believe they are going to be bright as sombich... As for the mounting spot, I have not yet decided. Have some messing around to do before I find the right spot. Wanna help me decide?
I quoted you before you changed it...
Old Mar 7, 2012 | 03:00 PM
Toreador_Diesel
Crafty...lol!
After doing some reading, I think you should be able to plug right in and go.
The stock bulb is 45w and it hooks to a 5 amp fuse, so the 1.8A @ 12V those fogs need are well within the specs.
You could mount them in the near stock location right below the middle front.
You could also mount them topside in front of the grill
Either way, it'll be sweeeeettttt....
Old Mar 7, 2012 | 03:04 PM
TXtinct's Avatar
TXtinct
Thanks for digging up the info for me. I almost sent you a PM asking if you wanted to go in on a set of 4 of these, it would've saved almost 20 bucks a pair. I'm considering putting some on the back end, depending on what these look like. Same deal goes there.
Old Mar 7, 2012 | 03:21 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Yes those will work, you need to get the polarity right because they are l.e.d.'s They are from super bight led.com, they come in both spot & flood type. I was thinking about those, but was worried about local law complaining how bright they are!
Old Mar 7, 2012 | 03:32 PM
TXtinct's Avatar
TXtinct
These are not from superbright, they charge for one light what I paid for two. I'm pretty sure they come from the same place though... I'll let you know how bright they are when I wire them up. I anticipate retna burn.
Old Mar 8, 2012 | 07:51 AM
kdbd4's Avatar
kdbd4
Great lights! My wife would kill me, because I wouldn't be able to resist turning them on as I'm pulling into the driveway!
I'm thinking they should work fine, but looks like you got your answers!
Have FUN!
Old Mar 8, 2012 | 08:31 AM
jasonodsky's Avatar
jasonodsky
TXtinct, You're gonna have to give up your source once you confirm they work well as driving lights. I'd love a set or two like that...for "off road use only" hahaha
Old Mar 9, 2012 | 02:44 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Id say Way Bright, i use a set of 10 watt's when backing up at night! IMG]https://www.ford-trucks.com/forums/picture.php?albumid=19526&pictureid=75645[/IMG]
Old Mar 9, 2012 | 03:06 PM
TXtinct's Avatar
TXtinct
Oooooohhhh, that's bright...
Old Mar 9, 2012 | 03:20 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Im sure other drivers won't like your Way bright fog/spot lights. I've left mine on by accident and the people behind me get agitated
Old Mar 9, 2012 | 03:44 PM
TXtinct's Avatar
TXtinct
I thought about putting some out back for those special occassions where someone tailgates me...
