How do I...
Old Mar 6, 2012 | 12:13 PM
xltblt's Avatar
xltblt
How do I...
So I need some information on how to re-do a bad heater core job, shocks, and help locate coolant leaks. Right now the truck has no coolant in it that I can see. The plastic radiator coolant thing does have fluid in it but not enough, way under the mark that it says on the tank. So what should I do?
Old Mar 6, 2012 | 01:19 PM
therifleman556's Avatar
therifleman556
Easiest way to find leaks would be to buy or borrow a radiator pressure tester, fill the radiator with antifreeze, and pressurize the system to 13 (ish) psi. Any leaks will be quickly obvious unless its a headgasket
Old Mar 6, 2012 | 02:31 PM
eatont9999's Avatar
eatont9999
Heater core is stupid easy. Take the glove box off and you are looking at the cover for the heater core. Unscrew the cover and pull it out. The all aluminum replacement cores don't fit well but people shove them in anyway. The copper/brass ones are the best fit.
Old Mar 6, 2012 | 03:37 PM
tjc transport's Avatar
tjc transport
i ain't rite
where abouts in sussex county are you?
jim jam sanders is outside of vernon. he knows almost anything you need to know about these rigs.
Old Mar 8, 2012 | 12:22 AM
xltblt's Avatar
xltblt
Im by high point state park, in wantage about 4 minutes from the sussex in.
burnthelight88
Nov 11, 2016 05:46 AM
anojones
Feb 10, 2009 04:56 PM
96expblk
Jan 30, 2007 11:50 PM
ledbetter
Jun 25, 2005 01:35 PM
nothingbutford
22
Sep 30, 2004 05:59 PM
