engine Check light
Old Apr 26, 2003 | 11:47 AM
xyz's Avatar
xyz
Question engine Check light
Eng Check light comes on intermitantly.
How do I troubleshoot this? Air care
failed with high hydrocarbon reading.
1988 f150 300 6cyl
Old Apr 26, 2003 | 02:23 PM
94van's Avatar
94van
engine Check light
First thing ya gotta do is pull the computer code(s) for a starting point.
Old Apr 26, 2003 | 02:31 PM
xyz's Avatar
xyz
engine Check light
Thanks, How do I do it? Can't find it in the manual.
Old Apr 26, 2003 | 06:19 PM
Silver Streak's Avatar
Silver Streak
engine Check light
If you havn't changed your O2 sensor in the last 50k miles or so, I would go down to your nearest Ford dealer and get a new one. That sounds like a likely candidate for your SES light. If the O2 is old it will tend to send a low (lean) signal to the PCM, which will dump more fuel into the engine. That would explain the high HC reading. Does the SES come on during a consistent set of running conditions, or is it completely random? Another possibility is the MAP sensor vacuum line. If it is deteriorated and cracked the MAP sensor will tell the PCM to add fuel.
Old Apr 27, 2003 | 03:04 AM
steve83's Avatar
steve83
engine Check light
Read this thread.
