Input Needed: 79 f350 or 73 f250
Hey guys, I'm looking for another project and here are the two finalists that I'm looking for input on. My ultimate goal is a 460 and C6 with 36-38" tires.
1973 F250 HB, 35" tires, 460 and c6 that have seen "A lot" of offroad. The body is beat, corners of the cab dented, and the front fenders don't sit straight. Dana 60 rear, 44 front big open hub, disc brakes, 4.10 gears. Edelbrock intake, holley carb, bored 30 over, runs and drives for $2300.
The second option:
1979 F350 regular cab, Dana 60 front and rear, 400m motor, c6, 3.54 gears I think, it looks like the low boy frame by its stance, but decently maintained body and interior, been sitting for about 9 years, asking $2100.
I've heard the f350's are great finds, so in the long run should I build up the f350 with a 460, lift it, and gear it or take the 73 how it is. Any input is appreciated! Thanks!
The second option:
Fixing a banged up body can take a huge amount of time and money. Also, if the F250 has seen "a lot" of hard off road use there may be additional problems with the frame and drivetrain. I'd go with the F350. Personaly, I'd probably rebuild and upgrade the 400, however, I understand 460 core engines are not too hard to find so the 460 upgrade would not be too hard or expensive.
Why are you pondering this!?!??! - There's no question!!
Go with the '79!
Pluses:
Integral power steering
Dana 60 Front (and rear)
400M (a good starting point, easy to swap to 460!)
400M C6 shares a bellhousing with the 460 = easy swap
Better body (rust/damage sucks!)
Bolt on 6" lift should fit 38" tires no problem! (33's fit at stock height!)
"Married" transfer case = better rear driveline angles (coming from a short-wheelbase Jeep person, heh)
Minuses:
You don't get to deal with hunting down parts to rebuild the crap stock power assist steering
You wouldn't get to say "it's a hi-boy" (or high-boy)
Won't fit the 36's/38's stock without a lift
Seriously, the '77.5-'79 trucks are awesome
-Brad
Go with the '79!
Pluses:
Minuses:
-Brad
turbospartan
30
07-13-2018 10:52 AM
sean_k
03-11-2003 02:04 AM
LK
11-30-2001 04:45 PM
