I recently purchased the L.E.D. bulbs for my turnsignals and corner markers.
I can run the back L.E.D.s and the corner markers with no problem. Although the blink rate is considerably faster on the turnsignals, they all work.
However, when I install and run the front turnsignal L.E.D.s together with the back I get no blinking (all the right lights are on, just no blinking) and a buzzing noise. If I replace the stock bulb the blinking resumes.
I am thinking the L.E.D.s are not causing enough "resistance" (I hope that is the right term) to make the flasher cycle?
Anybody have any experience, educated opinions, or ideas?
Standard blinkers just plain don't like LEDs. I replaced the blinker units in both trucks with electronic ones. In the second truck, the blinker unit is a little different. The owner designed a programmable blinker for that truck and now it blinks in lots of interesting patterns. (makes people nuts when he signals a turn. )
