Ideas to prevent expensive HPFP system repairs
#107
#109
Is the 6.7 powerstroke one of a kind? As in compared to the 6.7 Cummings, 6.6 duramax, or even the 6.4 powerstroke. They all burn the same fuel. What prevents them from failing? Seems like no matter how you add it up, there will always be a little water in your tank. It's called condensation.lol any time a rise and fall in temps occur, moisture is drawn. Even just the humidity over time will accumulate. I have no dealings with the 6.7 so there is alot i dont understand, but the one thing that sticks out to me is the need for additive or some sort of lubrication.
#112
#116
Rickatic knows that battle first hand.
Dieselcraft.com Diesel Fuel Purification Systems
portable and tank water detectors at above site; plus polishing, filters, etc.
Water Test for Diesel Fuel || Fleet Biodiesel
http://www.fleetbiodiesel.com/dropbo...structions.pdf
Fleet Biodiesel Diesel and Biodiesel Fuel Test Kit Water and Visual Clarity, 12 Tests, Model# FT-0100 | Bio-Diesel Processing | Northern Tool + Equipment
test kits at above sites (not really real low on detection level of water; confirms if above 200ppm)
KITPLANES Newsline
Parkland, note the comment in above link:
"Wiebe is also open to experimenting with the probe detecting water in diesel fuel....." I have had my share of electronics projects and don't have time to play anymore; but, perhaps this is something you could capitalize on?
Watect 550 Water Sensor Alarm Module
New Online Moisture Detection Sensor For Real-time Alarming
above is an in-line flow sensor; lots of reading on this company or their sensor if you search: EESIFLO
Diesel fuel test kits
http://www.velcon.com/datasheet/VFTKits2073.pdf
above detects as low as 100ppm water
$10/kit is more than I would be willing to add to my fueling costs.
Bob
KITPLANES Newsline
Bob
#117
Dealership's "never hearing about it" is something i consider a lame excuse. It goes along with "We called ford, and they never heard of any similar issue."
I can't speak for everyones eperience, but I remember several years ago, a friend of mine took his 6.0 L 350 in cause the EGR malfunctioned and the intake was oiled and sooty, and they replaced almost everything except the engine itself. They're recurring comment was:
"Geez, I can't imagine what you did to this truck, we've never seen any problems with this engine compared to other engines, oh well, at least we took care of you."
And when he asked if they had any other 6.0 l trucks in for repairs, and if so, what type? :
"Oh no, ford really got it right with this engine, it's a keeper. We haven't had any issues with it at all. "
And I'm one of the few that believes the 6.0 engine isn't nearly as bad as some think.
#119
Regards
