Having issues after plug change??
Old Mar 4, 2012 | 08:46 PM
tooldad's Avatar
tooldad
Papa Tiger,
Narrowed tractor issue to starter or switch. Took a mallet to the starter, and voila, it cranked. Guess I need to be looking for a replacement. thanks.
Old Mar 5, 2012 | 06:59 PM
Greg B's Avatar
Greg B
I would suspect starter. With a helper, use a digital multimeter or a volt meter to see if you are getting voltage to the starter when the switch is turned to the start position. If you are, it's the starter.
Old Mar 6, 2012 | 10:06 PM
tooldad's Avatar
tooldad
Truck update - Service Engine light came on tonight. Great. Will check codes tomorrow.
Tractor update - Still cranking. Online dealer says $566 - $706 for new OEM starter!!! Definitely will look at aftermarket if necessary (<$200).
Old Mar 7, 2012 | 10:18 AM
Rudeman's Avatar
Rudeman
Mabe the #2 plug was damaged in the drop after all.
Good Luck and keep us posted.
jovialwoodchuck
Aug 1, 2018 02:08 PM
krisinwa
2004 - 2008 F150
Nov 22, 2017 09:10 AM
Matt300ZXT
Feb 17, 2017 08:34 AM
VCB
Modular V10 (6.8l)
Sep 29, 2013 05:19 PM
lamenytro
1983 - 2012 Ranger & B-Series
Oct 23, 2010 08:24 PM
