352FE Harmonic Balancer question
Old Jun 30, 2012 | 03:25 PM
  #31
RussG's Avatar
RussG
Bill, I did find a number on the water pump pulley you might be able to reference. It has an upper # A8E, then D20E 8509AA.
Old Jul 1, 2012 | 01:43 AM
  #32
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RussG
VIN: F10AN872037
I did find a number on the water pump pulley you might be able to reference. It has an upper # A8E then D2OE-8509-AA.
F10 = F100 2WD
A = 240 1V I-6.
N = Norfolk VA Assembly Plant.
872037 = 1966, assembled June 1966.
A8E = Manufactured the 5th (E) week of January (A), 1978 (8). The pulley, not necessarily the engine it came from.
Marked D2OE-8509-AA = Ford part number: D2OZ-8509-A .. W/P Pulley-6 7/32" O/A diameter / Applications:
1972/76 Torino/Montego 302/351W A/C / 1974/76 Cougar 302/351W A/C / 1976/80 Granada/Monarch 302/351W A/C / 1977/78 LTD 302/351W A/C / 1977/79 Thunderbird/Cougar/Ranchero/LTD II (not LTD!) 302/351W A/C.
Old Jul 1, 2012 | 01:54 AM
  #33
smokenchoken's Avatar
smokenchoken
another route i might suggest
how about running it off of the water pump sheaves by themselves i know its not perfect or 100 percent right but it worked on my 67 i had till the day she met her new owner
Old Jul 2, 2012 | 05:30 PM
  #34
RussG's Avatar
RussG
F10 = F100 2WD
A = 240 1V I-6.
Wow! Thanks Bill. I think we are getting closer to indentifying this engine. I also found a tag on the power steering gear, HCE-G 128547. I doubt it is the original with this truck. It has a torn rubber coupler that connects the steering shaft to the input shaft of the gear box and needs to be replaced. Where can I get one and what is the correct nomenclature and PN?
Old Jul 2, 2012 | 06:30 PM
  #35
smokenchoken
that disk
that disk you are referring to is a steering coupler disk you can buy them at any part store that is worth its salt personally im not a big fan of them i remove them and chuck them as far as i can throw them i replace mine with grade 8 bolts from local hardware store and double nut them....you have to leave small amount of slack otherwise your steering will occasionally bind up and thats just as bad as the disk failing in its own rights i have put 30,000 miles on the 2 grade 8s and they have only the slightest signs of wear on them and i was replacing disks every 10,000 but its your choice
Old Jul 2, 2012 | 07:47 PM
  #36
NumberDummy
I also found a tag on the power steering gear, HCE-G. I doubt it is the original with this truck.
HCE-G = 1966 F100/250 2WD Bendix P/S Gearbox.
C5TZ-3A525-A .. Steering Coupler / Obsolete
Applications: 1965 F100/250 2WD / 1966 F100/250 2WD before serial number 900,001.
HASELDEN BROTHERS in Hemingway SC has 1 = 843-558-2134.
GREEN SALES CO. in Cincinnati OH has 49 = 800-543-4959.
CARPENTER NOS OBSOLETE Parts in Concord NC has 105 = 800-476-9653.
Old Jul 6, 2012 | 05:16 PM
  #37
RussG's Avatar
RussG
Otay, finally got the crank pulley and balancer numbers...
pulley...D3AE-6312-CA
balancer.... E4TE-A3A
Old Jul 6, 2012 | 07:25 PM
  #38
NumberDummy
D3AZ-CA = D4AZ-6A312-A .. 4 Sheave Outer Pulley / 1973/79 Passenger Car 302/351M/351W.
E4TE-A3A = E4TZ-6316-A .. Harmonic Balancer / 1984/89 F150/250 302.
Old Jul 10, 2012 | 04:26 PM
  #39
RussG's Avatar
RussG
Thanks again Bill,
Any chance you can find out what vehicle the power steering pulley goes to? The number is 5Z-ATA
Old Jul 11, 2012 | 01:18 AM
  #40
NumberDummy
No such ID number, it's most likely this puppy:
D5ZZ-3A733-A .. Single Sheave P/S Pulley ~ 5 13/16" diameter ~ 1/2" sheave width / Marked: D5ZW-AA or A1A
1975/78 Mustang II 302 with/without A/C / 1978/79 Thunderbird/Cougar/Ranchero/LTD II (not LTD!) 302/351M/351W/400 / 1978/80 Granada/Monarch 302 without A/C / 1978/82 Fairmont/Zephyr 302 with A/C.
1980/86 F100/250 302 / 1981/83 F100/150 255 / 1981/86 F150/350 351W / 1983/86 Thunderbird/Cougar 302 / 1984 Continental Mark VII 302.
Frankenstein monster, similar to real life: Same research scenario, but no parts counter, no greasy parts to match up.
lamont
Aug 1, 2017 09:55 AM
whackit
Sep 23, 2012 04:40 PM
Log Hog Kust'em
Jul 12, 2012 03:29 PM
nonoodlez
May 2, 2011 05:57 PM
hollygreenman
Oct 19, 2010 09:52 AM
