Out of state help!
Old 03-01-2012, 10:56 PM
kennedyford's Avatar
kennedyford
kennedyford is offline
Out of state help!
Long story. Dad truck blows engine, dad takes mine.
My truck. Fresh oil change pulls good.
With towing trailer truck starts to stumble. 2000 f350.
He cleaned ipr, and replaced ipr with known good spare.
Nope.
Replace 3 injectors
Nope
replaced idm...ran alot better then......nope.
Replaced fuel pump....
Nope
Old 03-01-2012, 10:58 PM
kennedyford
Opps posted too soon from phone.
Truck pulls good for about 30 miles, then to running like crap and no hill power.
Pull over to cool down...repeat.
Old 03-01-2012, 11:00 PM
rare_f8's Avatar
rare_f8
rare_f8 is offline
How is the CPS? And the UVCH are ok?
Old 03-01-2012, 11:13 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Sounds like a fuel pressure issue... Have you checked the fuel pressure?
Why the hell would you replace 3 injectors?
Old 03-01-2012, 11:28 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Where is the truck?
Old 03-01-2012, 11:50 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Definitely sounds like fuel related issues, if you'll post the location maybe someone can help.
Old 03-02-2012, 12:47 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Good to see you around after almost two years.
Pop
Old 03-02-2012, 06:13 AM
papadelogan's Avatar
papadelogan
papadelogan is offline
Snowboard season cometh..
Barney (bfife) had a similar issue about a year back. Turned out to be cruddy fuel clogged his fuel filter. This he discovered after replacing all the cups for his injectors and some other work. I'd hate that you'd wasted money for 3 injectors but sincerely hope it's that simple, but it definitely sounds like fuel starvation:
1. clogged filters (in-tank? fuel bowl? pre-pump all good?)
2. pinched line
3. dying fuel pump
Old 03-02-2012, 11:47 AM
kennedyford
Virginia. Stan pm me and I will send out phone number.
Old 03-02-2012, 12:01 PM
bfife's Avatar
bfife
bfife is offline
still plays with trucks
sounds EXACTLY like the issue I was having last yr while I was traveling from Louisiana to Wyoming. Spent a lot of money and time. chasing that that little gremlin. Put a guage on it and I'll almost guaranty you see the pressure drop to nothing while driving. pressure idling don't mean poo, it's pressure running down the road with a load behind it. you can also install a vaccum guage between the tank and pump. Ford says anything over 6lbs of vaccum means the tank screens are plugged. this test IS AT IDLE.
Barney
Old 03-02-2012, 01:13 PM
kennedyford
I meant his name is stan. Anyone that could help pm me
Old 03-02-2012, 03:13 PM
kennedyford
Pop
Yes it has been a while. Economy took its toll. Career change and additional family makes internet time not so important.
But helping family is. This site has always pulled through.
Update......
Ipr changed because the idiot..me...put that weeee lil tiny rod in backward and the subsequent problem was that truck was wanting maximum demand.
So, that is fixed.
Sensor on driver side (ipc) changed, oil leaking into wiring.
Fuel pump was changed.......hose runs free and clear diesel directly from tank. Both fuel filters my primary spin on and the engine were changed. No change.
So talking to him today, truck runs screaming great until it warms up or 30 miles. He has been breaking down on side of the road on this trip. He pullled a few of the injectors and found that the top oring was shady or possibly worn because of high oil pressure?
Now he is in process of pulling the injectors to replace the seals/orings as they may be letting oil pressure by after the engine heats up.
Now he has limped both the truck and trailer to Raphine Virginia exit 205 at the Petro.
Old 03-02-2012, 03:21 PM
kennedyford
Oh yeah, Idm replaced too. It was failing.
Old 03-02-2012, 03:34 PM
bfife's Avatar
bfife
bfife is offline
Update......
So, that is fixed.
Yeah, but whats your fuel Pressure? you're assuming its OK. could be screens in the heads, could be a bad pressure regulator. Franco just had that issue. get a guage om it before you spend any more time and money. Know what you've got.
Barney
Old 03-02-2012, 04:41 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Again, sounds completely like a fuel supply issue.
Without knowing the pressure your throwing good money after bad, and you could be opening up new problems.
Quick Reply: Out of state help!
