2005 Start problem
Old Mar 1, 2012 | 02:16 PM
adbscu's Avatar
adbscu
2005 Start problem
I have a 2005 PSD that for the past few months has been giving me trouble starting and the dealer could not figure it out (tested alternator/batteries). Here is some info (not very mechanically inclined so excuse some bad terminology):
-after sitting for a few days the batteries won't have enough juice to crank
-if i try to crank the speedo/rpm needs will trickle a little
-hook it up to a trickle charger to let it charge and everything works fine. Charger will read one of the batteries to be almost dead
perhaps the cabling between the Alt/batteries is bad? or something is drawing power?
any ideas?
Old Mar 1, 2012 | 03:39 PM
2006powerstroke90's Avatar
2006powerstroke90
Are they original batteries from 05? If they are...I would say its time for a change...
All your symptoms are looking like bad/low batts when you crank it up.
Check all cables/grounds and give em a good cleaning.
Test and verify alt output
rawdeal
Mar 22, 2014 06:18 PM
F-750pickup
Dec 19, 2013 02:04 AM
Diesel Junky
Mar 12, 2013 09:43 PM
mark6x43
Oct 26, 2009 07:24 PM
clay
Dec 30, 2008 08:14 AM
