What are the part numbers for the master cylinder and power booster used in a 72 f100 with power drum brakes? I bought a 79 donor truck and have managed to strip the power steering out of it along with the dump bed but I am being evicted so I ran out of time and the disk brake swap will have to wait, I have other members of my family that need to be able to drive my truck so we can move and i'd prefer if they were able to stop it so for the time being I am just thinking of upgrading them to power.
Pretty sure I would need the master with the booster? I don't see how my non boosted master cylinder would reach the peddle? It might? Although it is rusted up pretty bad and lacking a gasket so it wouldn't hurt to replace it.
it should be i put it in advance auto sand it said it was a perfect fit. I have power brakes on my 68, but i couldn't find any numbers to help you out with. they may be there i just can't find them
here's the link so you can see (i didn't know what motor you had so i put in 360 but that shouldn't affect the brakes haha). by the way, this one is an adjustable rod
I looked at that one but the rod is different mine has the open hoop on the end of it with a bolt holding it to the peddle. if its not the right length I'll cut it and weld it to fit =/
