Another tuner Q
Old Feb 29, 2012 | 02:38 AM
garndog's Avatar
garndog
Another tuner Q
I know i want the SCT tuner. is the livewire 9600 the way to go or no?
Old Feb 29, 2012 | 02:55 AM
npccpartsman's Avatar
npccpartsman
It's not nicknamed the lemonwire for no reason--LOL
Old Feb 29, 2012 | 02:58 AM
garndog's Avatar
garndog
so that's a no go on that tuner. What makes it a bad if you don't mind.
Old Feb 29, 2012 | 03:02 AM
npccpartsman
They may have seriously improved it, I don't know to be honest. If you want a livewire because of the gauge options there are much better/cheaper alternatives IMHO.
Old Feb 29, 2012 | 03:07 AM
garndog's Avatar
garndog
I also want to upgrade my STC HPOP Fitting and oil rail plug. sinister has the fitting but not the plug. any suggestions? what do you recommend for tuner and gauges?
Old Feb 29, 2012 | 05:36 AM
npccpartsman
SCT X3 for the tuner without a doubt. Gauges depends on how much $$$ you want to spend. You can get a Scan Gauge II and monitor everything the PCM sees and then add a fuel pressure and EGT gauges because the PCM can't monitor those. There is also the Edge Insight that's very popular but more $$$ than SGII. Regardless, running a tuner I recommend fuel pressure and EGT gauges.
Tlberry
Oct 14, 2015 09:49 PM
