Nevada Chapter Join Chapter, Leader:67 Olfthfl
EMERGENCY Someone needs help with his 6.4L in Laughlin!!
Old 03-17-2012, 04:10 PM
shorebird's Avatar
shorebird
shorebird is offline
10 minutes ago.
Industrial_dude needs help in Laughlin.
Stuck on side of road.
Stuck with oil leak down the back of engine.
Ford Truck Enthusiasts Forums - View Single Post - Oil gushing stuck on side of road
Old 03-18-2012, 09:26 AM
R1_Demon's Avatar
R1_Demon
R1_Demon is offline
Just saw this today at 7:30 am.
Old 03-18-2012, 09:37 AM
shorebird's Avatar
shorebird
He was able to get somewhere.
If he leaves the filler cap off the leak seems to stop.
Check his OP.
https://www.ford-trucks.com/forums/1...l#post11588486
Old 03-18-2012, 01:17 PM
R1_Demon's Avatar
R1_Demon
R1_Demon is offline
Weird...definitely a build up of pressure in the engine to make it leak if the oil cap is on, but not leak if there is a way for the pressure to escape.
Almost sounds like a plugged PCV (in a normal engine) problem, but he says he checked the line and it's not clogged. Then again, it could be clogged inside where he can't see/get to. I don't know anything about diesels, so I can't help him there.
Just sounds like the exhaust gasses aren't escaping properly and thus building pressure into the engine and making the oil squirt out wherever it can find a place to do so. Bad thing is, even after the pressure issue is fixed, he will probably have to replace whatever seals the oil squirted out of because they are now probably permanently damaged.
soberdude94
12-30-2012 11:57 PM
lee1964
06-21-2011 09:51 AM
rockwind1
11-10-2010 05:30 PM
Shepard69
07-12-2006 11:52 PM
Rudecube
Aerostar
01-07-2005 01:37 AM
Quick Reply: EMERGENCY Someone needs help with his 6.4L in Laughlin!!
