Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
6.0 will not even turn over.
Old 05-13-2012, 12:03 PM
dmaccord1's Avatar
dmaccord1
dmaccord1 is offline
I have a 06 F350 with a 6.0 liter. Yesterday it died while in the back country. Have full power but the truck will not even turn over. Totally dead but has power and ignition acts like everything is working. The check wrench light is on. Need help asap.
Thanks,
Don
Old 05-13-2012, 03:00 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Welcome to FTE. 6.0 in a 350 is diesel right? Might get more answers over there. Next, my first guess would be your starter or starter solenoid is shot. I don't know how the diesels work in starting methods, heck i learned not too long ago they use glowplugs to warm the cylinders not spark plugs. Anyways if you do have a similar setup as a gasoline try the solenoid bypass trick and see if that works.
Old 05-13-2012, 03:41 PM
dmaccord1's Avatar
dmaccord1
thanks. Will try it.
Thanks will try your suggestion.
Old 05-13-2012, 03:43 PM
GruesomeJeans
Yup no problem.
E30325i
01-06-2013 12:07 PM
99hosss
07-22-2012 03:01 AM
freshy930
1999 to 2016 Super Duty
04-07-2009 10:55 PM
Abbottdan
06-18-2004 06:22 AM
Quick Reply: 6.0 will not even turn over.
