Pass. side manifold leak?
Old Feb 27, 2012 | 04:36 PM
Powerstroke-7.3's Avatar
Powerstroke-7.3
i have been hearing an exhaust leak recently and decided to take a look at it yesterday and found a steel tube fitting screwed in the the front of the passenger side exhause manifold on the very end. I do not see anything that should be hooked to it but i see where a steel line broke off of the fitting. I have plugged it for the time being but am very curious of why its there. Any suggestions would help thanks.
-Alex-
Old Feb 27, 2012 | 05:03 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
exhaust back pressure tube? the other end should be connected to the sensor just above and to the left of your water pump pully. or left of the HPOP cover.
Old Feb 27, 2012 | 05:08 PM
Mr. Finch's Avatar
Mr. Finch
what you have found is the ebp sensor (exhoust back pressure sensor) it monitiors the exhoust pressure in the pass manifold. if you look at the front of the engine by the hpop reservoir you will see the sensor mounted on to the rest of that tube. it is comon and all it is there for is the ebpv (exhoust back pressure valve) wich helps with warm up and smoke in cold weather. if you do a search you will find alot of info and alot of peaple who removed the valve part to reduce exhoust restriction. the biggest thing to be warried about right now is that the leak will couse a loss of turbo boost wich will bring down power and mpg's.
hope this helps.
Old Feb 27, 2012 | 05:12 PM
Powerstroke-7.3
I have already un-plugged my ebpv solenoid so is it ok if i just keep the plug in the manifold?
Old Feb 27, 2012 | 05:22 PM
stinson 108-1
stinson 108-1
your pcm uses data from that sensor for fueling. i know DP tuner uses its info for tuning.
some do just plug it, but i would suggest you R&R it. there is a thread here on how. you can get the parts from Riff Raff, not much money if the sensor is good. it can affect your MPGs negatively.
Old Feb 27, 2012 | 05:51 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The EBPV and EBPS are NOT related.
The EBPS is used to control fueling and provide the PCM with, you guessed it, back pressure information.
The EBPV is used to put a load on the motor.
The EBPS can adversely affect your MPG, but it wont always. Seems to be no rhyme or reason as to why, but there are plenty of confirmed reports of recovered MPGs after cleaning..
http://www.youtube.com/watch?v=XLZI2wMpn5I
Old Feb 27, 2012 | 05:59 PM
stinson 108-1
stinson 108-1
there you go. theres the vid. what Trey and Trauma Junkie said. sensors are there for a reason. watch the vid. and fix it. good luck.
Old Feb 27, 2012 | 06:06 PM
timmyboy76's Avatar
timmyboy76
Maybe i should invest in a EBP tube and sensor, since i'm seeing 18-19mpg, and mines plugged with a npt cap on a RUINED sensor....been that way for over a year.
Old Feb 27, 2012 | 06:10 PM
stinson 108-1
stinson 108-1
Timmy, maybe you could get 21-22, HA!
Old Feb 27, 2012 | 06:33 PM
timmyboy76's Avatar
timmyboy76
I get those numbers, from time to time...18-19mpg all day long.
Old Feb 27, 2012 | 06:43 PM
stinson 108-1
stinson 108-1
AH, a 6 spd.I use to have a OBS with a 5 spd. got up to 23 if conditions were right.
Old Feb 27, 2012 | 07:50 PM
timmyboy76's Avatar
timmyboy76
EXACTLY...my first response was not of being a smart-***, but wondering if i'm limiting my mileage. Theres a few members here get'n better than what i'm get'n, and with an auto...
Old Feb 27, 2012 | 07:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
i know a guy pushin 30... yupp, 30.
Old Feb 27, 2012 | 08:04 PM
timmyboy76's Avatar
timmyboy76
Damn, if i could push that, i wouldnt care what the price of diesel was nor run wvo.
Old Feb 27, 2012 | 08:07 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I'm getting closer and closer to putting ATF in my tank with the way fuel prices are going... I'm running stock injectors anyway. Money saved on fuel can buy me stage 1s
