Hood Alignment
Old Apr 25, 2003 | 12:14 AM
DeanG's Avatar
DeanG
Hood Alignment
I have a 78 F250 Ranger Supercab 4X4. After removing an reinstalling the hood I can't seem to get the back edge back down to the correct height so that it lines up with the cowls height. I have the tried various positons with the three mounting bolts for the hinges but so far the best I can get is still about a half inch higher than the cowl. Does anyone have any experience and or fixes for this problem?
Old Apr 25, 2003 | 01:34 AM
Mil1ion's Avatar
Mil1ion
Hood Alignment
This was just discussed.
However because this forum is MOST replied on the site,The info you require has probably moved to page 2,3,4.
You can access those pages and the bottom of this page.
Look for the title with HOOD in it.
Old Apr 25, 2003 | 02:34 AM
macguyver's Avatar
macguyver
Hood Alignment
You're right Dennis. I should start a file of common answers.
The trick to get the rear of the hood down is to loosen the hinges on the inner fender and rotate them open farther. What happens is the last bit of hinge movement drops the rear down. If you set the hinges so the hood opens farther, the hinge "swings" a little more toward the closed position, dropping the back end down.
Hope this helps.
Greg
Old Apr 25, 2003 | 03:34 AM
GeneStoner's Avatar
GeneStoner
Hood Alignment
I just had this exact problem with my hood and Mac gave me the same advice. It is counterintuitive, but he is right. It works!
Old Apr 25, 2003 | 10:11 PM
DeanG's Avatar
DeanG
Hood Alignment
Thanks for your help guys:
I tried what you suggested and it worked. I kinda suspected I might need to do that but thought I would check with "those in the know" first.
Old Apr 26, 2003 | 04:14 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hood Alignment
I am thinking about turning the sticky thread that Dennis started into a FAQ section.
abe
Jul 2, 2021 12:21 PM
Rusty_S
Jan 27, 2015 08:51 PM
dieseldodgeguy
Jul 5, 2013 04:07 PM
mudder460
Appearance & Dress-Up
Aug 6, 2011 05:19 PM
