56 F100 Overhead Consoles ?
#31
You can match the contour of the top with a technique called scribing. Cut a piece of extra wide cardboard or 1/8 hardboard to length between the windows or however far you want the console to come back. Hold it up and roughly draw the contour and cut it out. Move the pattern up and hold in place. Set a simple school compass (one with a point and a pencil like you used in grade/highschool to draw circles) So the point is against the roof and the pencil is directly vertical below at a spacing that is slightly wider than the biggest gap between the rough pattern and the roof. Now (IMPORTANT!) without tipping or turning the compass run the point along the roof, tracing the profile onto the pattern with the pencil. Recut your pattern along the pencil line and check for fit. Rescribe and recut if it doesn't fit. Now you can make several copies of the contour pattern and try different shapes and thickness to fit you needs. Once you have a shape you like, cut a second one and a filler strip the width of the console, tape together and tape to the roof to test the shape. Cut out the openings for whatever you want to install and make sure it will fit before building out of more permanent material like wood or metal.
I would be willing to make high quality custom overhead or floor consoles in metal fiberglass, or wood for the 56, or if there was enough interest manufacture multiples of more universal/ generic design fiberglass ones. My 56 is a panel, so I could not make a full length one unless someone wants to bring me their pickup to use to develop the pattern.
#32
There is no reason to lose your cowl vent just because you modify your dash...I still have my cowl vent even with the dash mods I have made.
#33
Ax- I like that lower dash extension! Kinda finishes off the bottom of the dash like alot of cars are. These truck dashes do look like they are missing something at the bottom, and that's a nice approach to it. Very cool center console too, clean and simple.
Now is that console easily removed in the event that you'd wanna pop that transmission cover off? Nice work tho.
There is a brushed SS panel that covers the flat part of the dash. The lower extension is not flat but comes out to a peak like the top edge of the dash but smaller, and angles back at the bottom.
#34
Two bolts under the dash lip and two screws into angle brackets at the floor accessible by lifting out the rubber drink holders and it's out.
#35
I think I'm going to remove the gauge cluster hump in the dash and mount my gauges in the flat part of the dash.
#36
Awesome! Very nice work, definately well thought out!
#38
just found this. I am looking for ideas for my 53. What kind of stations does it get? Do you have a cd player somewhere else? So closer look, this looks like an original radio/speaker housing that has a modern radio in it. What is the radio?
#40
Secretaudio SST - Secret Audio Hidden Radio | Classic Car Stereos
Im using this...with the face mounted in the dash
F100supercrew
04-16-2018 03:26 PM
Weave
10-28-2003 05:17 AM
