Driveshaft angle
Old Feb 24, 2012 | 04:59 PM
2Hick's Avatar
2Hick
Driveshaft angle
As you can see, the front diff is not at the same angle as the radius arm and driveshaft. Is this going to be a problem?
Old Feb 25, 2012 | 01:52 PM
jhooch's Avatar
jhooch
I saw in your other post that you installed offset C bushings. Are they installed backwards. The thinner part of the bushing should be at the rear bottom and front top, therefore rotating the axle back. Viewing the vehicle from the side, your upper ball joints should behind the lower ball joints. This means you have positive caster. If they are not, not only is your pinion angle off, but this truck will be a handful to drive as well. You may need to drop the radius arm brackets down as well.
Prof2113
Aug 3, 2012 12:00 AM
RA81222
1978 - 1996 Big Bronco
May 13, 2008 02:22 PM
kurtdaims
Aerostar
Oct 13, 2003 12:27 PM
fast_eddy
26
Jul 4, 2003 11:24 AM
