Is it possible
Old Feb 23, 2012 | 06:19 PM
white04kr's Avatar
white04kr
Is it possible
For a headgasket to leak oil? I got an oil leak on my 04. It's covering the driver side head on the rear also covering the exhaust manifold too then it's dripping off the transmission bellhousing. I have some pictures but can't post from my cell.
Thanks for any info.
Old Feb 23, 2012 | 06:29 PM
utjer's Avatar
utjer
Check your cac tubes from the turbo. Most leaks like that are from them getting oil soaked and leaking through.
Old Feb 23, 2012 | 06:34 PM
white04kr's Avatar
white04kr
They are good. There is way to much oil to be leaking from cac boots. I have some pictures I'm trying to post.
Old Feb 23, 2012 | 07:08 PM
Snuggyworm's Avatar
Snuggyworm
it might be leaking from the HPOP or icp or ipr valve.
i would pull off everything from the top jus to get a better view.
for a headgasket to do tat, it must be an overboost condition. but then again, by tat time, there will be other symptoms like shudder, rough idling, etc. u should see signs like tat before something big blows. thar she blows, cap'n!
i hope i might help steer in the right direction. i'm sure the other experienced guys like zhilton, bismic, cheezit, npccpartsman, etc., will chime in later.
heck, ah might even be wrong somewhat. my brain's a little fuzzy but if i'm right, i'm sure the guys will say i'm right. hehehehe.
i wish u the best, pal. hope it turns out ok.
Old Feb 23, 2012 | 10:41 PM
brickie's Avatar
brickie
Please explain how the HPOP leaks externally.
Op sounds like the icp sensor if it is an early 04 or a turbo drain tube if not.
Old Feb 23, 2012 | 11:06 PM
m-chan68's Avatar
m-chan68
GUYS GUYS GUYS. Where does ANY overhead valve (or cam in block) engine deliver its lubrication to the valvetrain through?
Old Feb 23, 2012 | 11:08 PM
Snuggyworm's Avatar
Snuggyworm
hpo leak can come from under the fuel bowl in the valley. if o-rings are bad, tat can cause a leak. bad oil pressure can cause the o-rings to blow out.
like i said, my brain's a little fuzzy. long day. hey, it was bad and terrible too. sorry if i cant be specific at tat time or if i sounded snappy or unclear. i was jus apologizing in advance in case i mis-diagnosed by accident. tat way, when bismic or cheezit or zhilton corrects me, i wont look so bad cos i apologized in advance.
after all, we're all here to learn something. i may have been an engineer but tat doesnt mean i cant be fallible. if i made any mistakes, i humbly apologize.
Old Feb 23, 2012 | 11:09 PM
Snuggyworm's Avatar
Snuggyworm
by way of rolling valve train?
Old Feb 23, 2012 | 11:13 PM
Snuggyworm's Avatar
Snuggyworm
hydraulic roller lifter? at tis point, i'm drained and blank in the head. sorry m-chan68, u got tis one. i'm jus not feeling meself today. dang. now i'm jus rambling. sorry y'all.
Old Feb 23, 2012 | 11:14 PM
m-chan68's Avatar
m-chan68
What I meant, is HOW is lubrication (ie ENGINE OIL) delivered to all the valvetrain components (ie valves, rocker arms etc.) on ANY OHV engine? As in through WHERE?
Old Feb 23, 2012 | 11:17 PM
m-chan68's Avatar
m-chan68
DING DING DING!!!
Bingo!!! My point exactly. If engine oil is delivered through the hydraulic lifter, and then through the pushrods (or pushTUBE in Navistar speak), and then turn to the rocker arms, WHERE are there oil passages in the cylinder heads themselves to pass through?
Old Feb 23, 2012 | 11:25 PM
Snuggyworm's Avatar
Snuggyworm
damn, tat was a lucky shot. my brain's still running fizz all around.
return holes in the cylinder heads?
Old Feb 23, 2012 | 11:28 PM
Snuggyworm's Avatar
Snuggyworm
it has to circulate. i'm guessing the oil pump, in this case the hpop, forces the oil thru pushrods to valvetrain to lubricate rocker arms, but for oil to be continually pumped, the oil has to go back to the oil pump. hence, there must be some sort of return holes on the cyleinder heads for the oil to go back to oil pump, then for the oil pump to redo the entire process of pumping thru pushrods and so on and so forth.
Old Feb 24, 2012 | 04:35 AM
white04kr's Avatar
white04kr
It's an 06/04. This weekend I'm going to steam clean the intake under the turbo and the rest of engine where oil has leaked at. Then i will go from there. I have some pictures I can email someone to post for me.
Old Feb 24, 2012 | 08:26 AM
m-chan68's Avatar
m-chan68
My point exactly. That said, the chances of having an oil leak concern from the cylinder head gaskets are ...... ????
