Voltage Regulator fo 12v conversion
Old Feb 23, 2012 | 03:42 PM
mbarrad's Avatar
mbarrad
I'll be converting my truck to 12 volt this weekend. Do I need to bypass my voltage regulator once I switch to an alternator? Pardon my ignorance, but electrical systems are not my strong point. What happens if I leave it connected? As I understand it, the voltage regulator regulates electricity to the generator. Ya'll are always a good resource for helpful info.
Old Feb 23, 2012 | 04:12 PM
dennisb56's Avatar
dennisb56
what type of alternator are you putting in? If its a GM it most likely has the regulator built in. I just picked up a 63amp GM 3 wire alternator and its has a built in regulator. You also will need a new starter solenoid relay switch and possibly a new key switch and remove the push buttton. At least thats what I am doing. It's a shame you are so far away. Good luck.
Old Feb 23, 2012 | 04:15 PM
mbarrad's Avatar
mbarrad
Nevermind. I found my answer.
Old Feb 23, 2012 | 04:16 PM
mbarrad's Avatar
mbarrad
Got all that! I'm ready to do this!
Old Feb 23, 2012 | 04:21 PM
dennisb56's Avatar
dennisb56
that's the sprit! Good luck.
Old Feb 23, 2012 | 04:27 PM
mbarrad's Avatar
mbarrad
Thanks! I'll need it
Old Feb 23, 2012 | 11:58 PM
workaholic's Avatar
workaholic
Lights too
don't forget about the coil, and all the bulbs.
raye321
Jul 27, 2014 05:35 AM
Links_vette
Mar 30, 2009 12:20 PM
tequilaq
Electrical Systems/Wiring
Dec 25, 2006 11:58 AM
19644x4
Jan 8, 2004 03:27 AM
Sawbones25
Jul 4, 2003 08:00 PM
