55 grille
Old Feb 22, 2012 | 08:50 AM
jozan's Avatar
jozan
55 grille
Does a 55 f100 grille have a slight curve across the horizontal parts of it? I have one i want to put on my truck but its needs some work i put it on the table the headlight buckets are level on table but the rest has a curve outwards
Old Feb 22, 2012 | 08:55 AM
56panelford's Avatar
56panelford
If you mean it's bowed out in the center that is probably correct. Install it to your truck and if the center brace lines up with the attachment holes you'll know for sure. I have a 55 grille I can go out and check.
Old Feb 22, 2012 | 10:20 AM
jozan's Avatar
jozan
yep thats what i meant thanks that helps caues i was going to straighten it, thought i better ask somebody first, thanks for the help
Old Feb 22, 2012 | 10:31 AM
52 Merc's Avatar
52 Merc
I'm sure it's fine. Other years are the same way. And besides, having it bend outward would be the reverse of what happens when they run into something. It would be an unusual incident.
Old Feb 22, 2012 | 10:54 AM
CharlieLed's Avatar
CharlieLed
All of them have a bow outwards, it matches the curve of the valance and the hood. Pure flat panels are not very pleasing to the eye, it's hard to find a "flat" panel on these trucks other than the bed.
#1_Redneck88
Oct 3, 2012 05:51 PM
CharlieLed
May 12, 2011 08:35 AM
FLgargoyle
Jan 2, 2005 04:03 PM
