6.4 on Bio-diesel
Old 02-22-2012, 06:58 AM
DynamoDale's Avatar
DynamoDale
DynamoDale is offline
6.4 on Bio-diesel
I was wondering if I could run on bio-diesel or what I would have to do to my 6.4 run on Bio-deisel.
Old 02-22-2012, 09:30 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Thought I heard that you can't run it in the newer diesels (post 6.0) due to the emissions controls. Something about injecting unburned bio into the exhaust causing the Catalitic to plug. Might be wrong, hope someone else chimes in...
Old 02-23-2012, 04:31 AM
DynamoDale's Avatar
DynamoDale
Ahhh sense you mention that I do remember hearing something like that too.
Old 02-29-2012, 11:00 PM
97biostroke's Avatar
97biostroke
97biostroke is offline
From what I've read it's not that it plugs the filter, but the fumes pass through the crankcase during regeneration and the bio gets absorbed into the oil. #2 does the same thing, but the boiling point of #2 is low enough that it boils out during normal operation. Bio has a boiling point much higher, so it doesn't evaporate and adds up over time, diluting your oil. How big of an issue it is is debatable, but remove the DPF (delete pipe and a tuner) and you eliminate the problem.
slowmans
6.4L Power Stroke Diesel
08-01-2014 01:52 PM
gitane59
11-01-2011 06:59 PM
phillips91
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-21-2008 08:41 AM
esmarkey
25
03-08-2006 06:19 PM
Ssqtch
33
08-19-2004 08:26 PM
Quick Reply: 6.4 on Bio-diesel
