Random misfire code HELP
Old Feb 21, 2012 | 07:46 AM
mnmwhit's Avatar
mnmwhit
Had my truck in to the dealer for an HPOP failure. Turns out it was some leaky fittings.
Got new head gaskets and ARP studs while they were in that far.
And got the powermax turbo.
Now I am getting a random misfire code (engine light). Took it back and the put it on the computer (pids) and there is no misfire.
The tech is now saying he thinks it is a problem with my tuner not liking the turbo.
I dont have an EGR or cat.
Old Feb 21, 2012 | 08:30 AM
69cj's Avatar
69cj
It's always nice when people that need advice post what their truck is and any mods done to it.
Old Mar 7, 2012 | 08:21 AM
mnmwhit's Avatar
mnmwhit
I was using the I-phone app when I originally posted this. I didn't realize it doesn't post you "sig" (where I have my mods listed), when you use the app.
Old Mar 7, 2012 | 08:33 AM
mnmwhit's Avatar
mnmwhit
An update: The Tech called me last weekend and told me to run the truck on stock for a while and then put it back to what ever tune I want to run. He thinks the ECM/FICM needs to "learn"........
I did that and I am back in business. No codes and I LOVE THE TURBO!!
I got locked out of FTE for a while right when all this was happening could have used the advice availible here.
Truck originally went in for a "no start/long cranking times when it does start".
Had HPOP code.
Tech got in and found a leaky plastic fitting and recommended upgrading some other fittings that were better/updated. I had them do the headgaskets while he had the cab off. And the Powermax was an upgrade I have been wanting to do for a while.
I love the performance and the sound of the new turbo. Especially with my exhaust system. Cant wait to pull the trailer and check my mileage on the way back to Alaska this summer.
The only thing I am considering now for it is custom tunes. I have been useing the "canned" tunes that came with my SCT. I run on the performance setting most of the time.....and when I towed the trailer (20,000 lbs) down from Alaska last year I ran the 65+hp towing tune.
Old Mar 7, 2012 | 08:35 AM
mnmwhit's Avatar
mnmwhit
If I get a custom tune I will be trying to get better MPG while towing. I will only be pulling a 12,000 fifth wheel this time.
ajg617
May 11, 2014 12:55 PM
BRay09
Oct 19, 2010 09:41 AM
hifiman
Sep 12, 2010 09:28 AM
BossEliminator
Apr 21, 2010 11:22 AM
fhartell
Aug 2, 2007 08:04 PM
