welding precautions
Old Feb 20, 2012 | 08:34 PM
IDI guy's Avatar
IDI guy
Question welding precautions
I want to weld the dana 50 center mounts I keep breaking the bolts on the driver side mount, do I need to disconect any electrical stuff before I weld on the frame
Old Feb 20, 2012 | 09:16 PM
therifleman556's Avatar
therifleman556
Not unless your idi has an ecm. Even still, its easy enought to disconnect cables to be sure.
Old Feb 21, 2012 | 12:32 AM
joshofalltrades's Avatar
joshofalltrades
while disconnecting it shouldn't be necessary unless it has a computer, it sure can't hurt. but i usually just connect the ground clamp as close as i can and everything is fine.
if you don't already know, you want to clean the surfaces with a flammable solvent such as carb cleaner or acetone, NEVER use a non-flammable solvent such as chlorinated brake cleaner, as it can kill you to weld near it.
Old Feb 21, 2012 | 07:04 AM
fellro86's Avatar
fellro86
Had a truck that the frame had been shortened on, was originally a cab-chassis. The fuel senders were all burned out, who knows what all else was out from the high power welding, and likely did not disconnect. You can also take out alternators by welding. Doesn't always happen, but it sure can happen.
Old Feb 21, 2012 | 10:21 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
You should disconnect the battery for the Alternators sake.
-Enjoy
fh : )_~
Old Feb 21, 2012 | 11:56 AM
84-6.9L's Avatar
84-6.9L
And always ground to the piece you are welding, that way the current is less likely to travel where you don't want it to.
Old Feb 21, 2012 | 08:18 PM
ah1988's Avatar
ah1988
Not trying to be a a$$, but why do you keep breaking bolts? Are you driving the truck off cliffs LOL ?
The reason I ask is I have read several places that truck frames have carbon content to them. When you weld or heat up steel that is carbon steel it returns to mild steel no carbon content which would make the steel relativly "soft" . So if it is a mud truck you dont care about and abuse, I think it would be alright. But if you plan on driving it on the highway and you use it for mudding and towing heavy loads over the road, you may possibly run into (liability) problems. Remember the truck weighs 6-7k and if you impact
where you welded and truned the carbon steel into mild steel hard enough, you could bend or potentially tear that part of the frame .
Look up " welding on car/ truck frame" on welding web you will see what I am talking
about.
Hope this helped.
Old Feb 22, 2012 | 03:45 PM
Marianna2003's Avatar
Marianna2003
If you're breaking bolts, you need to look at how they broke. A conical failure is caused by overloading the bolt. Overtightening can be a problem too. Some times poeple tighten the daylights out of their fasteners eliminating the ability of carry ant additional load. I'm with ah1988. I'd go to Fastenal and get a set of their Grade 9 bolts before I broke out the welder.
Old Feb 22, 2012 | 03:55 PM
38Chevy454's Avatar
38Chevy454
about.
Hope this helped.
I am a metallurgical engr. Frames on our trucks are not heat treated and you can weld whatever you want. Assuming of course good welds and not severe undercut or other problems that can cause a crack initiation point.
The frames are mild steel. All steel has some carbon in it. If you have a lot of carbon it is cast iron. But generally mild steel is less than 0.40% carbon. Anything below 0.40% you can weld without preheat or postheat and almost any welding method will work. Welding on a heat treated part will mess up the heat treatment and you get a localized soft spot around the weld - this is probably what you are thinking about. It is not due to loss of carbon, it is due to the heat from welding.
To be honest, if you weld on our truck frames with MIG, the weld and area very near the weld will probably be harder (and correspondingly stronger) than the frame base metal. The only thing that makes our truck frames any stronger is due to the forming of the frame which does some cold working.
Old Feb 22, 2012 | 05:19 PM
ah1988's Avatar
ah1988
thanks for the info 38Chevy454, aren't some car/truck frames hardend ?
I just want to make sure I am not reading false info and spreading it around, thanks.
Old Feb 22, 2012 | 06:36 PM
Marianna2003
Some Class 8 truck dframes are heat treated. Therefore no welding should be done.
Welding is the last thing I would do on a frame. Bigger bolts, backing plates, & higher grade bolts are the better way to go. DOT frowns on welding on frames.
Old Feb 22, 2012 | 08:46 PM
IDI guy's Avatar
IDI guy
I will try and get the highest grade bolts I can get my hands on as far as overtightening them I set the torque wrench at 150 ft lbs which seems reasonable considering that it is a support bracket for the front of the truck. I still haven't welded anything I just put in a 1/2 inch grade 8 bolt in the spot and I will moniter it for breakage. Thanks for the welding info guys.
Old Feb 22, 2012 | 11:06 PM
84-6.9L's Avatar
84-6.9L
Keep in mind in some cases a grade 5 is better then a grade 8 because gr8 bolts are hard and are ment to have high tensile stregnth, but are more prone to shearing, a grade 5 is softer but has some "give" in it and wouldnt shear where the harder gr8 will.
Old Feb 22, 2012 | 11:23 PM
IDI guy's Avatar
IDI guy
Does anyone know the proper bolt and torque spec for the dana 50 axle mount bolts?
Old Feb 23, 2012 | 12:55 AM
joshofalltrades
i don't have the spec, but the front of just about every haynes/chilton manual out there has a "general info" section that includes "standard bolt torques" based on size and grade. or google that same torque chart i referred to in the books
