I re-read the original post and it sounds like the vehicle in question only has a lift and larger tires. No power mods listed. However, your point is still valid...I wouldn't be the least bit surprised if the dealer chose to void any potential warranty based on having larger tires. Seems like Ford is far more aggressive lately with warranty denials across the board...
I didn't design it with lift and tires so you altered it. Now you expect me to repair something that COULD have caused a problem? Really?
Also his sig said "3" downpipe, 4" MBRP exhaust, PHP 6-position tuner.". You going to make the case that they are like the fuzzy dice and have no effect on the drivetrain? I have seen techs that take personal pleasure in squealing to Ford about any mods they see so they can deny the warranty. Why? IDK.
So, for those of you running the 6.0L torque converter. What flex plate do you run? The 7.3L one or the 6.0L one?
6.0L is $75 cheaper.
I think what Joe meant was to purchase the TC that is normally paired with the HD4R100 trans since it's as good as a 6.0 converter but has the correct cover so it will bolt up to a 7.3 flexplate. I don't know if an actual 6.0 converter will work or not...doesn't seem like it would without some modifications...
I doubt the flexplate from a 6.0 would fit...very little is interchangeable between the two engines.
Rig Specs. 2001 Excursion 4x4. 7.3L. 4" Lift and 35s.
So, I am getting a really good rattle from my torque converter. I pulled the inspection cover and saw one nut on my flex plate that had backed off a little. Tightened it up, but still have the noise. The sound is coming from the TC. Its loud at idle and seems to be getting worse.
So, its time to upgrade. Most of my towing will be around 8000lbs or less. So, I want something that will hold up to that. I do plan to install a DP-Tuner in the next couple months as well. But, I doubt I will go over 325HP with this rig. Its my wife's daily driver and most of the time it will be in either Economy mode or Stock mode.
The tranny currently shifts fine and I have no issues with shifting at all. It was installed by Ford at 107K and now has 72K on it. So, I am at 179K on the X. The plan is to replace both the flex plate and the Torque converter with something a little better than stock.
So, what recommendations would you have? I would like to stick with the stock pump if possible, but am not opposed to upgrading if needed. I would just do a BTS or John Wood tranny, but don't have the funds just yet since I just bought this X with cash. Maybe by the end of tax season.
I believe the TC issue is with a 2001 Excursion.
The PHP is on his '96 F250...
At least that is what I gather anyway...
Those mods are on my 96' F250 (Year and model also listed in my sig)
Well, I've talked to two dealers and they don't have the TC by itself to look up. Any ideas on a part # or anything for the heavy duty TC?
Sorry, I do not. I've always just had my own TCs made on a custom basis since I like to specify my own stall speed. In my drag cars, we used to increase the stall speed for 1/4 mile performance but I don't think that applies to these trucks. However, I have zero knowledge about what it takes to make these things perform at the strip or serious off road. If you are interesting in 1/4 mile performance or serious off roading, then I am the last guy to listen to for advice.
In my world, I am interested in towing performance so a lower than stock stall speed seems to be what my trucks like. I think something around 1400-1450 rpm stall would be ideal for city driving or towing heavy loads. Also keep in mind that I have no experience with lifted trucks or oversized tires so what works for me may not work for you. There are a lot of guys on here that have specific experience with bigger tires so hopefully they can provide their insight so you can determine what is best for you.
Well I can replace the factory TC for $239. I just would like a heavier duty one if possible. I know I don't plan to do anything with the tranny yet, so maybe the stock TC would be fine until I order up a BTS or John Wood.
Even then, that tranny may be overkill for me.
Get that for your truck since you have miles on it and you are not rebuilding the trans.
Overkill in what sense? BTS is not only for racing. My trans is over 3 years old and out of warranty but based on what others have reported, when, not if it breaks. Brian will fix it for FREE. Peace of mind is what I am paying for in terms of a "Forever Warranty".
That is the plan I think at this point. Factory flex plate and factory TC for now. Then start saving for the BTS since its about a month out if not more with tax season here.
Well, scratch that. That $239 was a misquote by the dealer. Stock replacement TC is $417.
Call BTS first. IIRC, the waiting time is a month depending on the time.
Is the transmission under warranty still? If the previous owner paid to have it replaced, then it should have a 3 year 75k mile warranty that is transferable.
Something to look into...
Scroll down to the bottom of the page and you will see a few choices. I have the Bad Boy 4 disk TC because I tow super heavy. In your case you can easily get by with the Triple Disk model or maybe even their Tow Master model. Prices seem attractive. If you give them a call they might be able to make a recommendation for your particular application.
