I have a 93 f150 with a e4od transmission. I want to put a pillar mounted gauge in for the trans temp. Does anyone no of a place where i can put the sending unit?
I have read that some people put the sender in a pressure port on the drivers side of the transmission...
I do not know if this is correct or not, just what I have read..
I would think if it is designed to be a trans temp gauge sender it should have instructions included... If not I think I would maybe pass on it and look for better quality.
