Sponsored by: Real Truck
V10 questions
Old Feb 19, 2012 | 04:27 PM
88idigray's Avatar
88idigray
V10 questions
Alright guys, im thinking about making the plunge and buying a V10 the old idi with a three speed is killing me on fuel. A local dealer has a 2000 f-250 with the v10 in it. I was wondering what you guys think it could be worth. Its got 130000 miles, Its got all the options of the xlt package. The body is in decent shape with no rust. 4x4 extended cab. And BALD tires. I thought this would be the best place to see what it was worth. The dealer wants 7500 for it.
Old Feb 19, 2012 | 05:16 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yikes..
thats WAY to much based on my local market, but everywere is kinda different.
supply/demand and all that..
round here a 2000 Spercab 4x4 like that would be about 3500-4000$ max.
Old Feb 19, 2012 | 05:21 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Buying a V10 to save fuel may not be a realistic expectation....just an FYI.
Old Feb 19, 2012 | 05:58 PM
88idigray's Avatar
88idigray
Yeah I know the V10 isn't a fuel saver but compared to the 10 mpg im getting in the diesel on more expensive fuel anything above 10 is gonna help Haha
Old Feb 19, 2012 | 06:31 PM
IslandBlueV10's Avatar
IslandBlueV10
Hello here is a good post to read(https://www.ford-trucks.com/forums/8...-used-v10.html) it will help you evaluate this truck.
Right now with gas going up higher and higher, use that as a bargaining chip with the dealer, also use the bald tires, to get a lower price. I wouldn't have the dealer replace them unless he puts on what you want(otherwise they will probably put on the cheapest thing thay can find), then go put on some good tires.
But $7500 doesn't sound to bad, knowing what I know about the truck. I know in my area it probably would be a little higher. But still I would try to get it lower.
Old Feb 19, 2012 | 06:57 PM
88idigray's Avatar
88idigray
Its an Super Cab not the crew cab. I noticed a noise in the engine that doesnt go away. Im not one to know much about the ford engines but it sounds almost like a main knock, I couldn't hear it get louder as rpm's increased and I can't hear it in the cab. The truck was bought new from the dealer its at and according the service records it was always maintained at the dealer.
Old Feb 19, 2012 | 08:38 PM
kas83's Avatar
kas83
Probably a leaky exhaust manifold, very common, and attribute it to a knock. Use that as another way to get the price lower.
Old Feb 19, 2012 | 09:48 PM
88idigray's Avatar
88idigray
Yeah I looked at the manifold bolts and some are broke off. I just didn't know if that was the sound or not? Thanks for the help guys
Old Feb 19, 2012 | 10:24 PM
IslandBlueV10
Yeah if you have broken exhaust studs, use that to your advantage. They are time consuming to replace. If you have the ability and tools to do them, or you will have to pay to get them done. Do a search in the V10 forum on how to replace them. Also with that mileage the ball joints will probably need to be done, also maybe tie-rods. Do some research and check that truck out good or have someone else check it out for you. But don't let a little work scare you, just know what you are getting and try to get it for as little as you can to make up for it.
Old Feb 19, 2012 | 11:13 PM
moosey78's Avatar
moosey78
I have a 99 E350 with a V10 2wd auto. 286500 miles showing. I get between 10 and 15 city/highway. I paid 2k for mine and it was worth it. 75 seems a little steep for that truck. Now 5 I could see paying. But if you can get it at a good price you shouldnt be disappointed. They tow great. I pull 7000# with mine and you wouldn't know you had a trailer until you looked back.
Old Feb 20, 2012 | 05:55 AM
scraprat's Avatar
scraprat
Top Answer: 5
You can get all sorts of baseline amounts of what the truck is worth, but the bottom line is what are you willing to pay for it.
The truck is 11-12 years, tires $750-$1000, Calipers, rotors $125-200, Manifold bolts prices are all over the place. Then you start thinking of mods like changing the restrictive y in the exhaust. Mileage seems to be 12-14 from what others have posted in the V10 section of the forum. Good luck in search for a truck.
Old Feb 20, 2012 | 10:54 AM
wileyeyejeep's Avatar
wileyeyejeep
I just got a 2000 F250 4WD extended cab w/ V 10 145K on the ticker. Paid $4700 private sale. I had to replace the coil over plug boots this weekend. Picked up an engine misfire. Read about it on this forum and decided to start w/ the boots. Cyl 4 and 5 had bad boots. Misfire fixed and running like a champ again. So far I love the truck. Have not pulled our 8000lb travel trailer or my Jeep and car hauler yet, but I am expecting it to do much better than the Dodge 1500 did.
Old Feb 20, 2012 | 05:50 PM
FordRig's Avatar
FordRig
yep, a v10 is for someone who doesn't care about fuel mileage, for sure. a friend of mine sold a '04 f-250 2wd supercab with manual tranny (6-speed, i think). the only engine mod he had was jba headers and cold air system and it was super fun to drive. also, he put fiberglass fenders and bedsides with 37" tires. he gave it away at $16k though. i wish i coulda bought it from him...
Old Feb 20, 2012 | 06:12 PM
WestxSRT10's Avatar
WestxSRT10
Run away, and don't look back. That's way too much $ for a truck with those issues ( and likely more).
Old Feb 20, 2012 | 08:04 PM
Rosson03's Avatar
Rosson03
i have some good tips on miles to the gal. i cant post them but if you pm me i will send you the links
