My first issue popped up during this week. Only 20k on the clock (I don't put nearly the miles on this one like the 6.0) and I have a/c vents on the driver side spitting out hot air, while the vents on the passenger side spitting out cold (which is the way it should be as I have it set on 60).
Of course, out of all the issues that could have crept up, that one is relatively mild. Other then that, still enjoying the 150 immensely. Just wish it was a diesel, can't have it all, although certainly can wish/try.
The HVAC controller will set a dtc if its an electronic issue. Might be dealer time Tex!
Sorry it took me so long to get back to you. It appears that vloney was correct in is original assessment. Thankfully all done under warranty. I have about the same amount of miles as you do Brad.
